Pega session/cookie manage
Dear All,
We are running Pega 7.1.8 and want to apply the HA for my service. The topology as bellow
User ===https:443===>Netscaler-LB====http:9080===>WASND-Node01 + WASND-Node02
By following some document (How to configure a reverse proxy server), I already setup HTTP Header (at LB Level) : PegaRULES-SetContextURI. ContextRewriteEnabled to true in pegarule.xml. Checked in Pega Clipboard and pxReqContextURI is the same as PegaRULES-SetContextURI . When trying to test (shutdown 1 node), the Pega still asking for login again.
Am I miss in some step? My expectation is: if one of node die, the user can continue to work without disconnect (no need to login again).
