Virtusa Systems Pvt LTD
AE
Last activity: 9 Jan 2025 9:48 EST
Pega Selenium kit for CLM /KYC framework
Hi Everyone,
I have explored the pega selenium started kit and planning to implement to our client project.
https://community.pega.com/marketplace/component/selenium-starter-kit
Can anyone help me with the pre-requisites,
Can we use/implement the selenium started kit for Financial products like CLM /KYC or is it limited to use only the below mentioned framework.
If its a limited then please suggest a way to implement the selenium automation for Pega CLM KYC.
***Edited by Moderator Marije to add Case INC-B25228 tags***
Reply
Updated: 9 Jan 2025 9:48 EST
@Dinesha INC-B25228 was investigated by @sak01 and @ghors3 (with consultancy backup from @timer ) The main recommendation was to check with your IT team to investigate why there is a blockage preventing connection to the global Maven repository.
The support ticket has now been closed with the following resolution:
Solution description:
Client was facing issues in the implementation process using Maven. After further investigation, we came to know that the client is facing issue with creating and running any Maven project and its not only limited to this.
Informed client that they can be able to proceed with the implementation after they're able to create and run a sample Maven project.
@Dinesha I understand that there are time delays as you are working with client infra team to unlock for jar downloads for maven project. You requested GCS to close the support ticket as your tests may take some time.
If you do have updates to provide, please use the Reopen functionality on ticket INC-B25228 (What are the criteria for reopening a support ticket?).
This will allow the same engineers who have been working with you to pick up from where you left off.
Updated: 10 Jun 2024 3:58 EDT
⚠ Below is a GenAI-powered tool. All generated answers require validation against the provided references.
The Selenium Starter Kit is not limited to specific frameworks. It is designed to work with Pega applications, including financial products like CLM/KYC. However, the implementation complexities may vary depending on the specific requirements of your application. It's recommended to follow best practices for testing with Pega and Selenium.
Selenium Integration with Pega
Which testing automation tool should we use for automation
You can try to email pega-seleniumstarterkitsupport-external (at) pega (dot) com with your question.
@nagit as PO of the Selenium Starter Kit could you please answer the above question? cc @somis2
AE
We are planning to implement Selenium started kit for Pega CLM financial products.
Have posted some queries on this SSK.
Please provide your inputs to proceed further.
You can utilize SSK framework for any Pega Application. It’s not limited to above mentioned 3 applications.
Soujanya
Updated: 10 Jun 2024 7:30 EDT
AE
Thanks for the confirmation Soujanya.
Is there any Pega recommeded Project template for this SSK automation project.
If so , Kindly share it here , It will be helpful to align with pega recommendation.
Please take latest 'CRM Test Framework' project as reference and also follow Developer's guide for extending base framework for authoring tests which is available in selenium-starter-kit community portal.
Soujanya
Updated: 14 Jun 2024 6:01 EDT
AE
Hi @pulis2 i am working on this POC with minimal funcitonalities.
I am unable to run pom.xml and cucumber tests as well from cmd.
Need your support on this.
Also unable to download the sample test framework package from Selenium Extending Base Framework .
Please share the URL to download it.
Updated: 14 Jun 2024 10:47 EDT
Please follow 'Setup Guide' and 'Running Tests' documentation which is available On SSK page. For downloading the latest framework, please click on 'Version 4.2.2 (CRM Test Framework)' on SSK Page.(download link - Version 4.2.2 (CRM Test Framework). Could you please share more details on the error which you are getting while running the tests.
Soujanya
AE
Hi @pulis2 ,
unable to complete maven test. I got a error in framework jars and files.
[INFO] Scanning for projects... [WARNING] [WARNING] Some problems were encountered while building the effective model for com.pega.test:pega-crm-ui-testframework:jar:2.1.1 [WARNING] 'dependencies.dependency.systemPath' for com.pega.test:pega-base-ui-testframework:jar should not point at files within the project directory, ${project.basedir}/lib/pega-base-ui-testframework-2.1.1.jar will be unresolvable by dependent projects @ line 213, column 16 [WARNING] [WARNING] It is highly recommended to fix these problems because they threaten the stability of your build. [WARNING] [WARNING] For this reason, future Maven versions might no longer support building such malformed projects. [WARNING] [INFO] [INFO] [1m--------------< [0;36mcom.pega.test:pega-crm-ui-testframework[0;1m >---------------[m [INFO] [1mBuilding pega-crm-ui-testframework 2.1.1[m [INFO] from pom.xml [INFO] [1m--------------------------------[ jar ]---------------------------------[m [INFO] [INFO] [1m--- [0;32mbuild-helper:1.1:add-source[m [1m(add-source)[m @ [36mpega-crm-ui-testframework[0;1m ---[m [INFO] Source directory: I:\O\selenium\ootb-selenium-tests\src\main\java added. [INFO] Source directory: I:\O\selenium\ootb-selenium-tests\src\test\java added. [INFO] [INFO] [1m--- [0;32mresources:3.3.1:resources[m [1m(default-resources)[m @ [36mpega-crm-ui-testframework[0;1m ---[m [INFO] Copying 0 resource from src\main\resources to target\classes [INFO] [INFO] [1m--- [0;32mcompiler:3.0:compile[m [1m(default-compile)[m @ [36mpega-crm-ui-testframework[0;1m ---[m [INFO] Changes detected - recompiling the module! [INFO] Compiling 209 source files to I:\O\selenium\ootb-selenium-tests\target\classes [INFO] ------------------------------------------------------------- [ERROR] COMPILATION ERROR : [INFO] ------------------------------------------------------------- [ERROR] error reading C:\Users\Guest1\.m2\repository\org\aspectj\aspectjweaver\1.8.11\aspectjweaver-1.8.11.jar; Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/customerservice/interactions/impl/PegaInteractions.java:[1,1] cannot access com.pega.crm.customerservice.interactions.impl ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/pages/RealTimeContainer.java:[17,1] cannot access com.pega.crm.pegamarketing.pages ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/customerservice/SFAPortal.java:[1,1] cannot access com.pega.crm.customerservice ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/WorkObject.java:[1,1] cannot access com.pega.crm.salesautomation.workobjects ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/impl/PegaOrganization.java:[1,1] cannot access com.pega.crm.salesautomation.workobjects.impl ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/test/java/com/pega/crm/pegamarketing/stepdefs/Offerglue.java:[1,1] cannot access com.pega.crm.pegamarketing.stepdefs ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/impl/rules/PegaPropositionFilter.java:[1,1] cannot access com.pega.crm.pegamarketing.impl.rules ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/ExpressPortal.java:[1,1] cannot access com.pega.crm.pegamarketing ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/impl/pages/PegaTreatments.java:[1,1] cannot access com.pega.crm.pegamarketing.impl.pages ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/impl/elmt/PegaOfferShape.java:[1,1] cannot access com.pega.crm.pegamarketing.impl.elmt ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/utils/ObjectsBean.java:[1,1] cannot access com.pega.crm.pegamarketing.utils ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/elmt/Connector.java:[1,1] cannot access com.pega.crm.pegamarketing.elmt ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/impl/dialog/PegaButtonParametersDialog.java:[1,1] cannot access com.pega.crm.pegamarketing.impl.dialog ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/test/java/com/pega/CRMObjectsBean.java:[1,1] cannot access com.pega ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/dialog/ButtonParametersDialog.java:[1,1] cannot access com.pega.crm.pegamarketing.dialog ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/rules/SMSTreatment.java:[1,1] cannot access com.pega.crm.pegamarketing.rules ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/customerservice/tiles/impl/PegaLeftNav.java:[1,1] cannot access com.pega.crm.customerservice.tiles.impl ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/customerservice/impl/PegaSFAPortal.java:[1,1] cannot access com.pega.crm.customerservice.impl ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/test/java/com/pega/crm/salesautomation/stepdefs/Contact.java:[1,1] cannot access com.pega.crm.salesautomation.stepdefs ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/customerservice/tiles/TopNav.java:[1,1] cannot access com.pega.crm.customerservice.tiles ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/customerservice/interactions/OutboundPhoneCall.java:[1,1] cannot access com.pega.crm.customerservice.interactions ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/impl/PegaDesignerStudio.java:[1,1] cannot access com.pega.crm.pegamarketing.impl ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/impl/explorer/PegaRecordsExplorer.java:[1,1] cannot access com.pega.crm.pegamarketing.impl.explorer ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/test/java/com/pega/config/TestEnvInjector.java:[1,1] cannot access com.pega.config ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/test/java/com/pega/crm/customerservice/stepdefs/StartResearchInteraction.java:[1,1] cannot access com.pega.crm.customerservice.stepdefs ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/test/java/RunCukesTest.java:[2,1] cannot access unnamed package ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/explorer/RecordsExplorer.java:[1,1] cannot access com.pega.crm.pegamarketing.explorer ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/pages/SimulationServices.java:[5,8] cannot access java.lang ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/pages/SimulationServices.java:[6,9] cannot find symbol symbol: class By location: interface com.pega.crm.pegamarketing.pages.SimulationServices [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/pages/SimulationServices.java:[8,9] cannot find symbol symbol: class By location: interface com.pega.crm.pegamarketing.pages.SimulationServices [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/pages/SimulationServices.java:[9,9] cannot find symbol symbol: class By location: interface com.pega.crm.pegamarketing.pages.SimulationServices [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/OperatorList.java:[3,8] cannot access com.pega.crm.salesautomation ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/OperatorList.java:[3,39] cannot find symbol symbol: class WorkObject [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Operators.java:[3,8] cannot access com.pega.crm ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Operators.java:[3,36] cannot find symbol symbol: class WorkObject [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/OperatorList.java:[7,37] cannot find symbol symbol: class String location: interface com.pega.crm.salesautomation.workobjects.OperatorList [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Operators.java:[5,28] cannot find symbol symbol: class String location: interface com.pega.crm.salesautomation.workobjects.Operators [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Operators.java:[7,26] cannot find symbol symbol: class String location: interface com.pega.crm.salesautomation.workobjects.Operators [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Operators.java:[9,23] cannot find symbol symbol: class String location: interface com.pega.crm.salesautomation.workobjects.Operators [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Operators.java:[11,27] cannot find symbol symbol: class String location: interface com.pega.crm.salesautomation.workobjects.Operators [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Operators.java:[13,26] cannot find symbol symbol: class String location: interface com.pega.crm.salesautomation.workobjects.Operators [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Operators.java:[15,27] cannot find symbol symbol: class String location: interface com.pega.crm.salesautomation.workobjects.Operators [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Operators.java:[17,23] cannot find symbol symbol: class String location: interface com.pega.crm.salesautomation.workobjects.Operators [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Operators.java:[19,23] cannot find symbol symbol: class String location: interface com.pega.crm.salesautomation.workobjects.Operators [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Operators.java:[21,26] cannot find symbol symbol: class String location: interface com.pega.crm.salesautomation.workobjects.Operators [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Operators.java:[23,26] cannot find symbol symbol: class String location: interface com.pega.crm.salesautomation.workobjects.Operators [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Operators.java:[25,30] cannot find symbol symbol: class String location: interface com.pega.crm.salesautomation.workobjects.Operators [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Operators.java:[27,27] cannot find symbol symbol: class String location: interface com.pega.crm.salesautomation.workobjects.Operators [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Operators.java:[29,9] cannot find symbol symbol: class String location: interface com.pega.crm.salesautomation.workobjects.Operators [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Operators.java:[31,9] cannot find symbol symbol: class String location: interface com.pega.crm.salesautomation.workobjects.Operators [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Operators.java:[33,9] cannot find symbol symbol: class String location: interface com.pega.crm.salesautomation.workobjects.Operators [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Operators.java:[35,9] cannot find symbol symbol: class String location: interface com.pega.crm.salesautomation.workobjects.Operators [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Operators.java:[37,9] cannot find symbol symbol: class String location: interface com.pega.crm.salesautomation.workobjects.Operators [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Operators.java:[39,9] cannot find symbol symbol: class String location: interface com.pega.crm.salesautomation.workobjects.Operators [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Operators.java:[41,9] cannot find symbol symbol: class String location: interface com.pega.crm.salesautomation.workobjects.Operators [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Operators.java:[43,9] cannot find symbol symbol: class String location: interface com.pega.crm.salesautomation.workobjects.Operators [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Operators.java:[45,9] cannot find symbol symbol: class String location: interface com.pega.crm.salesautomation.workobjects.Operators [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Operators.java:[47,9] cannot find symbol symbol: class String location: interface com.pega.crm.salesautomation.workobjects.Operators [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Operators.java:[51,9] cannot find symbol symbol: class String location: interface com.pega.crm.salesautomation.workobjects.Operators [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Operators.java:[53,9] cannot find symbol symbol: class String location: interface com.pega.crm.salesautomation.workobjects.Operators [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/pages/DataManagement.java:[3,8] cannot access com ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/pages/LandingPage.java:[19,8] cannot access org ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/pages/LandingPage.java:[19,11] cannot access org.openqa ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/pages/LandingPage.java:[19,27] import requires canonical name for <any>.selenium.By [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/pages/LandingPage.java:[21,16] cannot access com.pega.framework ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/pages/LandingPage.java:[21,26] cannot access com.pega.framework.elmt ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/pages/LandingPage.java:[21,31] import requires canonical name for <any>.Frame [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/pages/LandingPage.java:[22,16] cannot access com.pega.util ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/pages/LandingPage.java:[22,21] package com.pega.util does not exist [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/pages/LandingPage.java:[24,38] cannot find symbol symbol: class Frame [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/pages/LandingPage.java:[25,9] cannot find symbol symbol: class By location: interface com.pega.crm.pegamarketing.pages.LandingPage [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/pages/LandingPage.java:[27,9] cannot find symbol symbol: class By location: interface com.pega.crm.pegamarketing.pages.LandingPage [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/pages/LandingPage.java:[28,9] cannot find symbol symbol: class By location: interface com.pega.crm.pegamarketing.pages.LandingPage [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/pages/LandingPage.java:[29,9] cannot find symbol symbol: class By location: interface com.pega.crm.pegamarketing.pages.LandingPage [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/pages/LandingPage.java:[30,9] cannot find symbol symbol: class By location: interface com.pega.crm.pegamarketing.pages.LandingPage [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/pages/LandingPage.java:[31,9] cannot find symbol symbol: class String location: interface com.pega.crm.pegamarketing.pages.LandingPage [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/pages/LandingPage.java:[32,9] cannot find symbol symbol: class By location: interface com.pega.crm.pegamarketing.pages.LandingPage [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/pages/LandingPage.java:[40,24] cannot find symbol symbol: class String location: interface com.pega.crm.pegamarketing.pages.LandingPage [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Opportunities.java:[3,8] cannot access java ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Opportunities.java:[3,12] cannot access java.util ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Opportunities.java:[3,17] import requires canonical name for <any>.ArrayList [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Opportunities.java:[6,40] cannot find symbol symbol: class WorkObject [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Opportunities.java:[8,24] cannot find symbol symbol: class String location: interface com.pega.crm.salesautomation.workobjects.Opportunities [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Opportunities.java:[12,22] cannot find symbol symbol: class String location: interface com.pega.crm.salesautomation.workobjects.Opportunities [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Opportunities.java:[14,27] cannot find symbol symbol: class String location: interface com.pega.crm.salesautomation.workobjects.Opportunities [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Opportunities.java:[16,25] cannot find symbol symbol: class String location: interface com.pega.crm.salesautomation.workobjects.Opportunities [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Opportunities.java:[18,34] cannot find symbol symbol: class String location: interface com.pega.crm.salesautomation.workobjects.Opportunities [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Opportunities.java:[20,25] cannot find symbol symbol: class String location: interface com.pega.crm.salesautomation.workobjects.Opportunities [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Opportunities.java:[20,9] cannot find symbol symbol: class String location: interface com.pega.crm.salesautomation.workobjects.Opportunities [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Opportunities.java:[22,23] cannot find symbol symbol: class String location: interface com.pega.crm.salesautomation.workobjects.Opportunities [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Opportunities.java:[24,24] cannot find symbol symbol: class String location: interface com.pega.crm.salesautomation.workobjects.Opportunities [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Opportunities.java:[26,29] cannot find symbol symbol: class String location: interface com.pega.crm.salesautomation.workobjects.Opportunities [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Opportunities.java:[28,31] cannot find symbol symbol: class String location: interface com.pega.crm.salesautomation.workobjects.Opportunities [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Opportunities.java:[30,25] cannot find symbol symbol: class String location: interface com.pega.crm.salesautomation.workobjects.Opportunities [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Opportunities.java:[34,22] cannot find symbol symbol: class String location: interface com.pega.crm.salesautomation.workobjects.Opportunities [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Opportunities.java:[36,24] cannot find symbol symbol: class String location: interface com.pega.crm.salesautomation.workobjects.Opportunities [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Opportunities.java:[40,27] cannot find symbol symbol: class String location: interface com.pega.crm.salesautomation.workobjects.Opportunities [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Opportunities.java:[44,28] cannot find symbol symbol: class String location: interface com.pega.crm.salesautomation.workobjects.Opportunities [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Opportunities.java:[48,38] cannot find symbol symbol: class String location: interface com.pega.crm.salesautomation.workobjects.Opportunities [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Opportunities.java:[50,16] cannot find symbol symbol: class String location: interface com.pega.crm.salesautomation.workobjects.Opportunities [INFO] 101 errors [INFO] ------------------------------------------------------------- [INFO] [1m------------------------------------------------------------------------[m [INFO] [1;31mBUILD FAILURE[m [INFO] [1m------------------------------------------------------------------------[m [INFO] Total time: 17.498 s [INFO] Finished at: 2024-06-15T15:24:07+04:00 [INFO] [1m------------------------------------------------------------------------[m [ERROR] Failed to execute goal [32morg.apache.maven.plugins:maven-compiler-plugin:3.0:compile[m [1m(default-compile)[m on project [36mpega-crm-ui-testframework[m: [1;31mCompilation failure[m: Compilation failure: [ERROR] error reading C:\Users\Guest1\.m2\repository\org\aspectj\aspectjweaver\1.8.11\aspectjweaver-1.8.11.jar; Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/customerservice/interactions/impl/PegaInteractions.java:[1,1] cannot access com.pega.crm.customerservice.interactions.impl [ERROR] ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/pages/RealTimeContainer.java:[17,1] cannot access com.pega.crm.pegamarketing.pages [ERROR] ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/customerservice/SFAPortal.java:[1,1] cannot access com.pega.crm.customerservice [ERROR] ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/WorkObject.java:[1,1] cannot access com.pega.crm.salesautomation.workobjects [ERROR] ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/impl/PegaOrganization.java:[1,1] cannot access com.pega.crm.salesautomation.workobjects.impl [ERROR] ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/test/java/com/pega/crm/pegamarketing/stepdefs/Offerglue.java:[1,1] cannot access com.pega.crm.pegamarketing.stepdefs [ERROR] ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/impl/rules/PegaPropositionFilter.java:[1,1] cannot access com.pega.crm.pegamarketing.impl.rules [ERROR] ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/ExpressPortal.java:[1,1] cannot access com.pega.crm.pegamarketing [ERROR] ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/impl/pages/PegaTreatments.java:[1,1] cannot access com.pega.crm.pegamarketing.impl.pages [ERROR] ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/impl/elmt/PegaOfferShape.java:[1,1] cannot access com.pega.crm.pegamarketing.impl.elmt [ERROR] ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/utils/ObjectsBean.java:[1,1] cannot access com.pega.crm.pegamarketing.utils [ERROR] ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/elmt/Connector.java:[1,1] cannot access com.pega.crm.pegamarketing.elmt [ERROR] ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/impl/dialog/PegaButtonParametersDialog.java:[1,1] cannot access com.pega.crm.pegamarketing.impl.dialog [ERROR] ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/test/java/com/pega/CRMObjectsBean.java:[1,1] cannot access com.pega [ERROR] ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/dialog/ButtonParametersDialog.java:[1,1] cannot access com.pega.crm.pegamarketing.dialog [ERROR] ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/rules/SMSTreatment.java:[1,1] cannot access com.pega.crm.pegamarketing.rules [ERROR] ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/customerservice/tiles/impl/PegaLeftNav.java:[1,1] cannot access com.pega.crm.customerservice.tiles.impl [ERROR] ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/customerservice/impl/PegaSFAPortal.java:[1,1] cannot access com.pega.crm.customerservice.impl [ERROR] ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/test/java/com/pega/crm/salesautomation/stepdefs/Contact.java:[1,1] cannot access com.pega.crm.salesautomation.stepdefs [ERROR] ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/customerservice/tiles/TopNav.java:[1,1] cannot access com.pega.crm.customerservice.tiles [ERROR] ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/customerservice/interactions/OutboundPhoneCall.java:[1,1] cannot access com.pega.crm.customerservice.interactions [ERROR] ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/impl/PegaDesignerStudio.java:[1,1] cannot access com.pega.crm.pegamarketing.impl [ERROR] ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/impl/explorer/PegaRecordsExplorer.java:[1,1] cannot access com.pega.crm.pegamarketing.impl.explorer [ERROR] ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/test/java/com/pega/config/TestEnvInjector.java:[1,1] cannot access com.pega.config [ERROR] ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/test/java/com/pega/crm/customerservice/stepdefs/StartResearchInteraction.java:[1,1] cannot access com.pega.crm.customerservice.stepdefs [ERROR] ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/test/java/RunCukesTest.java:[2,1] cannot access unnamed package [ERROR] ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/explorer/RecordsExplorer.java:[1,1] cannot access com.pega.crm.pegamarketing.explorer [ERROR] ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/pages/SimulationServices.java:[5,8] cannot access java.lang [ERROR] ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/pages/SimulationServices.java:[6,9] cannot find symbol [ERROR] symbol: class By [ERROR] location: interface com.pega.crm.pegamarketing.pages.SimulationServices [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/pages/SimulationServices.java:[8,9] cannot find symbol [ERROR] symbol: class By [ERROR] location: interface com.pega.crm.pegamarketing.pages.SimulationServices [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/pages/SimulationServices.java:[9,9] cannot find symbol [ERROR] symbol: class By [ERROR] location: interface com.pega.crm.pegamarketing.pages.SimulationServices [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/OperatorList.java:[3,8] cannot access com.pega.crm.salesautomation [ERROR] ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/OperatorList.java:[3,39] cannot find symbol [ERROR] symbol: class WorkObject [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Operators.java:[3,8] cannot access com.pega.crm [ERROR] ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Operators.java:[3,36] cannot find symbol [ERROR] symbol: class WorkObject [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/OperatorList.java:[7,37] cannot find symbol [ERROR] symbol: class String [ERROR] location: interface com.pega.crm.salesautomation.workobjects.OperatorList [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Operators.java:[5,28] cannot find symbol [ERROR] symbol: class String [ERROR] location: interface com.pega.crm.salesautomation.workobjects.Operators [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Operators.java:[7,26] cannot find symbol [ERROR] symbol: class String [ERROR] location: interface com.pega.crm.salesautomation.workobjects.Operators [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Operators.java:[9,23] cannot find symbol [ERROR] symbol: class String [ERROR] location: interface com.pega.crm.salesautomation.workobjects.Operators [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Operators.java:[11,27] cannot find symbol [ERROR] symbol: class String [ERROR] location: interface com.pega.crm.salesautomation.workobjects.Operators [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Operators.java:[13,26] cannot find symbol [ERROR] symbol: class String [ERROR] location: interface com.pega.crm.salesautomation.workobjects.Operators [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Operators.java:[15,27] cannot find symbol [ERROR] symbol: class String [ERROR] location: interface com.pega.crm.salesautomation.workobjects.Operators [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Operators.java:[17,23] cannot find symbol [ERROR] symbol: class String [ERROR] location: interface com.pega.crm.salesautomation.workobjects.Operators [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Operators.java:[19,23] cannot find symbol [ERROR] symbol: class String [ERROR] location: interface com.pega.crm.salesautomation.workobjects.Operators [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Operators.java:[21,26] cannot find symbol [ERROR] symbol: class String [ERROR] location: interface com.pega.crm.salesautomation.workobjects.Operators [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Operators.java:[23,26] cannot find symbol [ERROR] symbol: class String [ERROR] location: interface com.pega.crm.salesautomation.workobjects.Operators [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Operators.java:[25,30] cannot find symbol [ERROR] symbol: class String [ERROR] location: interface com.pega.crm.salesautomation.workobjects.Operators [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Operators.java:[27,27] cannot find symbol [ERROR] symbol: class String [ERROR] location: interface com.pega.crm.salesautomation.workobjects.Operators [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Operators.java:[29,9] cannot find symbol [ERROR] symbol: class String [ERROR] location: interface com.pega.crm.salesautomation.workobjects.Operators [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Operators.java:[31,9] cannot find symbol [ERROR] symbol: class String [ERROR] location: interface com.pega.crm.salesautomation.workobjects.Operators [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Operators.java:[33,9] cannot find symbol [ERROR] symbol: class String [ERROR] location: interface com.pega.crm.salesautomation.workobjects.Operators [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Operators.java:[35,9] cannot find symbol [ERROR] symbol: class String [ERROR] location: interface com.pega.crm.salesautomation.workobjects.Operators [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Operators.java:[37,9] cannot find symbol [ERROR] symbol: class String [ERROR] location: interface com.pega.crm.salesautomation.workobjects.Operators [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Operators.java:[39,9] cannot find symbol [ERROR] symbol: class String [ERROR] location: interface com.pega.crm.salesautomation.workobjects.Operators [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Operators.java:[41,9] cannot find symbol [ERROR] symbol: class String [ERROR] location: interface com.pega.crm.salesautomation.workobjects.Operators [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Operators.java:[43,9] cannot find symbol [ERROR] symbol: class String [ERROR] location: interface com.pega.crm.salesautomation.workobjects.Operators [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Operators.java:[45,9] cannot find symbol [ERROR] symbol: class String [ERROR] location: interface com.pega.crm.salesautomation.workobjects.Operators [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Operators.java:[47,9] cannot find symbol [ERROR] symbol: class String [ERROR] location: interface com.pega.crm.salesautomation.workobjects.Operators [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Operators.java:[51,9] cannot find symbol [ERROR] symbol: class String [ERROR] location: interface com.pega.crm.salesautomation.workobjects.Operators [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Operators.java:[53,9] cannot find symbol [ERROR] symbol: class String [ERROR] location: interface com.pega.crm.salesautomation.workobjects.Operators [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/pages/DataManagement.java:[3,8] cannot access com [ERROR] ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/pages/LandingPage.java:[19,8] cannot access org [ERROR] ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/pages/LandingPage.java:[19,11] cannot access org.openqa [ERROR] ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/pages/LandingPage.java:[19,27] import requires canonical name for <any>.selenium.By [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/pages/LandingPage.java:[21,16] cannot access com.pega.framework [ERROR] ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/pages/LandingPage.java:[21,26] cannot access com.pega.framework.elmt [ERROR] ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/pages/LandingPage.java:[21,31] import requires canonical name for <any>.Frame [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/pages/LandingPage.java:[22,16] cannot access com.pega.util [ERROR] ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/pages/LandingPage.java:[22,21] package com.pega.util does not exist [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/pages/LandingPage.java:[24,38] cannot find symbol [ERROR] symbol: class Frame [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/pages/LandingPage.java:[25,9] cannot find symbol [ERROR] symbol: class By [ERROR] location: interface com.pega.crm.pegamarketing.pages.LandingPage [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/pages/LandingPage.java:[27,9] cannot find symbol [ERROR] symbol: class By [ERROR] location: interface com.pega.crm.pegamarketing.pages.LandingPage [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/pages/LandingPage.java:[28,9] cannot find symbol [ERROR] symbol: class By [ERROR] location: interface com.pega.crm.pegamarketing.pages.LandingPage [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/pages/LandingPage.java:[29,9] cannot find symbol [ERROR] symbol: class By [ERROR] location: interface com.pega.crm.pegamarketing.pages.LandingPage [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/pages/LandingPage.java:[30,9] cannot find symbol [ERROR] symbol: class By [ERROR] location: interface com.pega.crm.pegamarketing.pages.LandingPage [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/pages/LandingPage.java:[31,9] cannot find symbol [ERROR] symbol: class String [ERROR] location: interface com.pega.crm.pegamarketing.pages.LandingPage [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/pages/LandingPage.java:[32,9] cannot find symbol [ERROR] symbol: class By [ERROR] location: interface com.pega.crm.pegamarketing.pages.LandingPage [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/pegamarketing/pages/LandingPage.java:[40,24] cannot find symbol [ERROR] symbol: class String [ERROR] location: interface com.pega.crm.pegamarketing.pages.LandingPage [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Opportunities.java:[3,8] cannot access java [ERROR] ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Opportunities.java:[3,12] cannot access java.util [ERROR] ZipException opening "aspectjweaver-1.8.11.jar": Invalid CEN header (invalid zip64 extra data field size) [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Opportunities.java:[3,17] import requires canonical name for <any>.ArrayList [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Opportunities.java:[6,40] cannot find symbol [ERROR] symbol: class WorkObject [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Opportunities.java:[8,24] cannot find symbol [ERROR] symbol: class String [ERROR] location: interface com.pega.crm.salesautomation.workobjects.Opportunities [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Opportunities.java:[12,22] cannot find symbol [ERROR] symbol: class String [ERROR] location: interface com.pega.crm.salesautomation.workobjects.Opportunities [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Opportunities.java:[14,27] cannot find symbol [ERROR] symbol: class String [ERROR] location: interface com.pega.crm.salesautomation.workobjects.Opportunities [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Opportunities.java:[16,25] cannot find symbol [ERROR] symbol: class String [ERROR] location: interface com.pega.crm.salesautomation.workobjects.Opportunities [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Opportunities.java:[18,34] cannot find symbol [ERROR] symbol: class String [ERROR] location: interface com.pega.crm.salesautomation.workobjects.Opportunities [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Opportunities.java:[20,25] cannot find symbol [ERROR] symbol: class String [ERROR] location: interface com.pega.crm.salesautomation.workobjects.Opportunities [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Opportunities.java:[20,9] cannot find symbol [ERROR] symbol: class String [ERROR] location: interface com.pega.crm.salesautomation.workobjects.Opportunities [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Opportunities.java:[22,23] cannot find symbol [ERROR] symbol: class String [ERROR] location: interface com.pega.crm.salesautomation.workobjects.Opportunities [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Opportunities.java:[24,24] cannot find symbol [ERROR] symbol: class String [ERROR] location: interface com.pega.crm.salesautomation.workobjects.Opportunities [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Opportunities.java:[26,29] cannot find symbol [ERROR] symbol: class String [ERROR] location: interface com.pega.crm.salesautomation.workobjects.Opportunities [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Opportunities.java:[28,31] cannot find symbol [ERROR] symbol: class String [ERROR] location: interface com.pega.crm.salesautomation.workobjects.Opportunities [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Opportunities.java:[30,25] cannot find symbol [ERROR] symbol: class String [ERROR] location: interface com.pega.crm.salesautomation.workobjects.Opportunities [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Opportunities.java:[34,22] cannot find symbol [ERROR] symbol: class String [ERROR] location: interface com.pega.crm.salesautomation.workobjects.Opportunities [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Opportunities.java:[36,24] cannot find symbol [ERROR] symbol: class String [ERROR] location: interface com.pega.crm.salesautomation.workobjects.Opportunities [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Opportunities.java:[40,27] cannot find symbol [ERROR] symbol: class String [ERROR] location: interface com.pega.crm.salesautomation.workobjects.Opportunities [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Opportunities.java:[44,28] cannot find symbol [ERROR] symbol: class String [ERROR] location: interface com.pega.crm.salesautomation.workobjects.Opportunities [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Opportunities.java:[48,38] cannot find symbol [ERROR] symbol: class String [ERROR] location: interface com.pega.crm.salesautomation.workobjects.Opportunities [ERROR] /I:/O/selenium/ootb-selenium-tests/src/main/java/com/pega/crm/salesautomation/workobjects/Opportunities.java:[50,16] cannot find symbol [ERROR] symbol: class String [ERROR] location: interface com.pega.crm.salesautomation.workobjects.Opportunities [ERROR] -> [1m[Help 1][m [ERROR] [ERROR] To see the full stack trace of the errors, re-run Maven with the [1m-e[m switch. [ERROR] Re-run Maven using the [1m-X[m switch to enable full debug logging. [ERROR] [ERROR] For more information about the errors and possible solutions, please read the following articles: [ERROR] [1m[Help 1][m http://cwiki.apache.org/confluence/display/MAVEN/MojoFailureException
Requesting your support to complete.
AE
@DineshaLooks like issue with some dependencies. Can you clear your local .m2 folder and do a clean install? let us know if same issue is persisted.
AE
@ghors3Sumit, I tried those steps already no luck.
mvn clean is done
m2 folder also cleared
Here i am pasting the logs for your reference.
mvn clean is done
[INFO] Scanning for projects... [WARNING] [WARNING] Some problems were encountered while building the effective model for com.pega.test:pega-crm-ui-testframework:jar:2.1.1 [WARNING] 'dependencies.dependency.systemPath' for com.pega.test:pega-base-ui-testframework:jar should not point at files within the project directory, ${project.basedir}/lib/pega-base-ui-testframework-2.1.1.jar will be unresolvable by dependent projects @ line 213, column 16 [WARNING] [WARNING] It is highly recommended to fix these problems because they threaten the stability of your build. [WARNING] [WARNING] For this reason, future Maven versions might no longer support building such malformed projects. [WARNING] [INFO] [INFO] --------------< com.pega.test:pega-crm-ui-testframework >--------------- [INFO] Building pega-crm-ui-testframework 2.1.1 [INFO] from pom.xml [INFO] --------------------------------[ jar ]--------------------------------- [INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/mojo/build-helper-maven-plugin/1.1/build-helper-maven-plugin-1.1.pom [INFO] ------------------------------------------------------------------------ [INFO] BUILD FAILURE [INFO] ------------------------------------------------------------------------ [INFO] Total time: 0.682 s [INFO] Finished at: 2024-06-19T12:58:14+04:00 [INFO] ------------------------------------------------------------------------ [ERROR] Plugin org.codehaus.mojo:build-helper-maven-plugin:1.1 or one of its dependencies could not be resolved: Failed to read artifact descriptor for org.codehaus.mojo:build-helper-maven-plugin:jar:1.1: The following artifacts could not be resolved: org.codehaus.mojo:build-helper-maven-plugin:pom:1.1 (absent): Could not transfer artifact org.codehaus.mojo:build-helper-maven-plugin:pom:1.1 from/to central (https://repo.maven.apache.org/maven2): repo.maven.apache.org: Unknown host repo.maven.apache.org -> [Help 1] [ERROR] [ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch. [ERROR] Re-run Maven using the -X switch to enable full debug logging. [ERROR] [ERROR] For more information about the errors and possible solutions, please read the following articles: [ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/PluginResolutionException
AE
@ghors3 sumit, I tried all the workaround for BUILD SUCCESS.
receiving the below jar dependency issues. Unable to sort out this issue.
Could not calculate build plan: Plugin org.apache.maven.plugins:maven-resources-plugin:2.6 or one of its dependencies could not be resolved: Failed to read artifact descriptor for org.apache.maven.plugins:maven-resources-plugin:jar:2.6 Plugin org.apache.maven.plugins:maven-resources-plugin:2.6 or one of its dependencies could not be resolved: Failed to read artifact descriptor for org.apache.maven.plugins:maven-resources-plugin:jar:2.6
@Dineshawe may have to connect on this. Is it feasible for you to send your project setup ? so we can take a look.
AE
@ghors3 Sure Sumit. I am connecting from client's laptop .
So, Please suggest a way to share the project setup or we can connect over the call.
Updated: 19 Jun 2024 11:36 EDT
AE
@ghors3 Sure. Do you require a remedy for this? Or can we discuss over the team link.
@Dinesha Can you please check if any network related restrictions preventing to downloading the dependencies/building the project. Because generally you should not be facing dependency download issues without any network restrictions. You can setup meeting if still issue is persisting. Team link should be fine.
@Dineshaok sure, in the meantime please try to provide some more logs on what is the current issue you are facing. I suggest to 1. Download the fresh repository from market place again (https://d2xbzkyevnvl4b.cloudfront.net/Pega_CRM_Selenium_UI_TestFramework_V4.2.2.zip). 2. Follow the pre-requisites from the 'Setup Guide' for jdk, maven installations and setting up path and any other pre-requisites. 3. Follow 'Running Tests' document to run the test case. Try running one test and share logs for any errors.
Virtusa Systems Pvt LTD
AE
@ghors3 I have tried with new framework. I am getting the below error once its imported to eclipse.
@Dineshaplease run below commands mvn -version below command will run installation with debug enabled. this is to get more logs. please share these logs mvn clean install -X Please check if below url is accessible from your system https://repo.maven.apache.org/maven2
AE
@ghors3 I am able to access the URL https://repo.maven.apache.org/maven2.
I tried the commands but it remains the same. I am unable to attach complete logs so attaching the caused by reason for your reference.
@Dinesha As discussed over the call, please check with security/firewall team on why for some dependencies, its getting blocked by 'maven-default-http-blocker'. Also try using this approach before downgrading maven to version below 3.8.1. Try the solution from this thread to unblock individual repositories or all repositories. https://stackoverflow.com/questions/66980047/maven-build-failure-dependencyresolutionexception
AE
@sak01Hi Kevin,
Downgraded the maven to 3.5.
still i am facing some issues while running the mvn install on cmd.
trying to resolve it based on the above mentioned link.
will let you know in sometime.
AE
@sak01 Hi Kevin,
I was gettign the below errors while connecting with Maven 3.5. Based on the previous discussed the proxy settings has been enabled.
---Log1
[ERROR] Plugin org.codehaus.mojo:build-helper-maven-plugin:1.1 or one of its dependencies could not be resolved: Failed to read artifact descriptor for org.codehaus.mojo:build-helper-maven-plugin:jar:1.1: Could not transfer artifact org.codehaus.mojo:build-helper-maven-plugin:pom:1.1 from/to central (https://repo.maven.apache.org/maven2): repo.maven.apache.org: Unknown host repo.maven.apache.org -> [Help 1]
---Log2
Failed to execute goal on project pega-crm-ui-testframework: Could not resolve dependencies for project com.pega.test:pega-crm-ui-testframework:jar:4.2.0: Failed to collect dependencies at com.pojosontheweb:monte-repack:jar:1.1 -> javax.media.jai:com.springsource.javax.media.jai.core:jar:1.1.3: Failed to read artifact descriptor for javax.media.jai:com.springsource.javax.media.jai.core:jar:1.1.3: Could not transfer artifact javax.media.jai:com.springsource.javax.media.jai.core:pom:1.1.3 from/to com.springsource.repository.bundles.external (http://repository.springsource.com/maven/bundles/external): repository.springsource.com: Unknown host repository.springsource.com -> [Help 1]
Hi Dinesh, Any update?
AE
@sak01 Hi Kevin, Sec team has informed that it's not related to port or firewall. And they suggested to provide the PORT number in case of firewall issues. Please let me know if you require details from my end. Also, could you suggest a way to bypass and proceed this activity. Cause it's been blocked to implement the SSK in client side for prolong time.
Updated: 9 Jan 2025 9:48 EST
@Dinesha INC-B25228 was investigated by @sak01 and @ghors3 (with consultancy backup from @timer ) The main recommendation was to check with your IT team to investigate why there is a blockage preventing connection to the global Maven repository.
The support ticket has now been closed with the following resolution:
Solution description:
Client was facing issues in the implementation process using Maven. After further investigation, we came to know that the client is facing issue with creating and running any Maven project and its not only limited to this.
Informed client that they can be able to proceed with the implementation after they're able to create and run a sample Maven project.
@Dinesha I understand that there are time delays as you are working with client infra team to unlock for jar downloads for maven project. You requested GCS to close the support ticket as your tests may take some time.
If you do have updates to provide, please use the Reopen functionality on ticket INC-B25228 (What are the criteria for reopening a support ticket?).
This will allow the same engineers who have been working with you to pick up from where you left off.
