Pega Robotics SP1 - Can InfoPath 2013 be interrogated?
Hi Pega community,
Can InfoPath 2013 be directly interrogated by Pega Robotics in order to create controls that Pega can reference and manipulate with automation? Infopath 2013 was once apart of the MS Office suite before being released as standalone. Currently MS Office integration is through connector - assumption is that this is the same for InfoPath but wanted to verify as this application isnt directly listed in the application Support Matrix.
Thank you for any help / feedback you can provide on this!
Kind regards,
Tim
Generally speaking, Office Applications require the use of connectors as their UI controls are ones that we do not currently have translators built for. Your mileage may vary on how much you can interrogate and work with from an adapter. I have not tried personally, but I would certainly perform some application discovery and testing with it before I planned to integrate it with a project.
