Pega Platform 8.23.0
Hi, On our setup, I attempted to replace a failling Stream node by another one (with a different name). But I cannot start it.
Beforehand, we upgraded from 8.6.1 to 8.23.0
The cluster state during new stream node starting up :
2023-11-27 14:55:15,475 [e-registry-heartbeat] [ STANDARD] [ ] [ ] (.tasks.TopologyChangedDetector) INFO - Services topology has changed. Current topology:
DataFlow.BackgroundProcessing naljbs700100.retraite.lan Proprietary information hidden NORMAL 8.23.0 bc46f4ff-27cb-4e05-a3f3-0490f0fc3f79
This node ==> DataFlow.BackgroundProcessing naljbs700178.retraite.lan Proprietary information hidden JOINING (new node) 8.23.0 5c4fcd69-3251-4c92-8b9b-7708cbc9baf6
DataFlow.Search naljbs700100.retraite.lan Proprietary information hidden NORMAL 8.23.0 6eef4091-24fe-4a33-a016-888196ebb7f8
This node ==> DataFlow.Search naljbs700178.retraite.lan Proprietary information hidden JOINING (new node) 8.23.0 17744249-8924-4eec-91e9-55dba45e2481
StreamServer.Default naljbs700100.retraite.lan Proprietary information hidden NORMAL 8.23.0 b6d19976-c72e-486a-8d53-6b3d8fce7d10
This node ==> StreamServer.Default naljbs700178.retraite.lan Proprietary information hidden JOINING_FAILED 8.23.0 178c0441-2382-41cb-a16f-ea67e9b5f261
pega naljbm700033.retraite.lan Proprietary information hidden running 8.23.0 f87da583-d5ed-4648-95fa-b62a9b9d0fa4
pega naljbs700100.retraite.lan Proprietary information hidden running 8.23.0 e7ea872f-0232-4b8c-a6a0-dfe68b1d7393
This node ==> pega naljbs700178.retraite.lan Proprietary information hidden startingUp (new node) 8.23.0 3d972cf9-e171-421b-91ef-8d4a5207323a
One error :
2023-11-27 14:35:50,767 [StreamServer.Default] [ STANDARD] [ ] [ ] (prpc.service.ServiceDefinition) ERROR - Failed to start service: [StreamServer.Default]
com.pega.dsm.dnode.api.StreamServiceException: Cannot add new node. Make sure all listed nodes are available or reattach the volume from one of these nodes to this node.
[Node=naljbs700113.retraite.lan, broker=1002]
at com.pega.dsm.dnode.api.server.StreamServerService$StreamServiceStartOperation$2.emit(StreamServerService.java:675) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.stream.DataObservableImpl$SafeDataSubscriber.subscribe(DataObservableImpl.java:353) ~[d-node.jar:?]
naljbs700113.retraite.lan is my old stream node.
I have not reference of this node in any of the following tables (I didn't drop them) :
- pr_sys_statusnodes
- pr_sys_statusdetails
- pr_data_stream_nodes
- pr_data_stream_node_updates
- pr_data_stream_sessions
Another error :
Caused by: org.postgresql.util.PSQLException: ERROR: column "pxprocessingnodeid" does not exist
Position: 96
at org.postgresql.core.v3.QueryExecutorImpl.receiveErrorResponse(QueryExecutorImpl.java:2676) ~[?:?]
at org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutorImpl.java:2366) ~[?:?]
at org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecutorImpl.java:356) ~[?:?]
at org.postgresql.jdbc.PgStatement.executeInternal(PgStatement.java:496) ~[?:?]
at org.postgresql.jdbc.PgStatement.execute(PgStatement.java:413) ~[?:?]
at org.postgresql.jdbc.PgPreparedStatement.executeWithFlags(PgPreparedStatement.java:190) ~[?:?]
at org.postgresql.jdbc.PgPreparedStatement.execute(PgPreparedStatement.java:177) ~[?:?]
at org.jboss.jca.adapters.jdbc.CachedPreparedStatement.execute(CachedPreparedStatement.java:303) ~[?:?]
at org.jboss.jca.adapters.jdbc.WrappedPreparedStatement.execute(WrappedPreparedStatement.java:442) ~[?:?]
at com.pega.pegarules.data.internal.store.DatabasePreparedStatementImpl.execute(DatabasePreparedStatementImpl.java:532) ~[prprivate-data.jar:?]
at com.pega.pegarules.data.internal.access.Lister.listWithResultPackager(Lister.java:421) ~[prprivate-data.jar:?]
... 43 more
I don't know why this column is missing in the DB ?
A last error :
2023-11-27 14:37:26,416 [OBSCHEDULER_THREAD_5] [ STANDARD] [ ] [ ] (.SearchManager.ESSearchManager) WARN - Checking cluster state failed. Reason: FTS is not initialized.
com.pega.pegarules.priv.search.nextgen.FTSNotInitializedException: Initialization of full text search is either in progress or has failed on this node. Please check the logs if search initialization is complete.
at com.pega.platform.search.internal.ESSearchProviderEmbedded.getSearchNode(ESSearchProviderEmbedded.java:309) ~[search.jar:?]
at com.pega.platform.search.internal.ESSearchProviderEmbedded.getSearchNode(ESSearchProviderEmbedded.java:50) ~[search.jar:?]
at com.pega.platform.search.searchmanager.internal.ESSearchManagerEmbedded.getSearchNode(ESSearchManagerEmbedded.java:83) ~[search.jar:?]
at com.pega.platform.search.searchmanager.internal.ESSearchManagerEmbedded.getClusterState(ESSearchManagerEmbedded.java:270) ~[search.jar:?]
at com.pega.platform.search.searchmanager.internal.ESSearchManagerEmbedded.lambda$isReady$0(ESSearchManagerEmbedded.java:90) ~[search.jar:?]
at com.pega.platform.search.infrastructure.es.TimeoutHandler.withTimeoutHandling(TimeoutHandler.java:108) ~[search.jar:?]
at com.pega.platform.search.searchmanager.internal.ESSearchManagerEmbedded.isReady(ESSearchManagerEmbedded.java:89) ~[search.jar:?]
at com.pega.platform.search.searchmanager.internal.AbstractSearchManager.isReady(AbstractSearchManager.java:63) ~[search.jar:?]
at com.pega.platform.search.indexmanager.internal.ESIndexAdminEmbedded.verifyClusterIsReady(ESIndexAdminEmbedded.java:364) ~[search.jar:?]
at com.pega.platform.search.indexmanager.internal.ESIndexAdminEmbedded.getIndicesInfo(ESIndexAdminEmbedded.java:371) ~[search.jar:?]
at com.pega.platform.pegasearch.indexadmin.internal.PegaIndexAdminImpl.getIndicesInfo(PegaIndexAdminImpl.java:530) ~[pegasearch.jar:?]
at com.pega.pegarules.management.internal.system.operations.ClusterManagementUtils.searchIndexSettingsToObject(ClusterManagementUtils.java:221) ~[prprivate-management.jar:?]
at com.pega.pegarules.management.internal.system.operations.ClusterManagementAPI.getClusterSearchStateWithParams(ClusterManagementAPI.java:639) ~[prprivate-management.jar:?]
at com.pega.pegarules.management.internal.system.operations.ClusterManagementAPI.getClusterSearchStateForCurrentContext(ClusterManagementAPI.java:625) ~[prprivate-management.jar:?]
at com.pega.pegarules.management.internal.system.operations.ClusterManagementAPI.getSystemStateForSingleNode(ClusterManagementAPI.java:313) ~[prprivate-management.jar:?]
at com.pega.pegarules.management.internal.system.operations.ClusterManagementAPI.getSystemState(ClusterManagementAPI.java:244) ~[prprivate-management.jar:?]
at com.pega.pegarules.management.internal.system.operations.ClusterManagementAPI.persistNodeState(ClusterManagementAPI.java:1058) ~[prprivate-management.jar:?]
at com.pegarules.generated.activity.ra_action_pzpersistnodestate_95416bc413b38e19928c1cbb46614741.step1_circum0(ra_action_pzpersistnodestate_95416bc413b38e19928c1cbb46614741.java:165) ~[?:?]
at com.pegarules.generated.activity.ra_action_pzpersistnodestate_95416bc413b38e19928c1cbb46614741.perform(ra_action_pzpersistnodestate_95416bc413b38e19928c1cbb46614741.java:76) ~[?:?]
at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:2876) ~[prprivate-session.jar:?]
at com.pega.platform.executor.jobscheduler.internal.ActivityExecutor.runActivity(ActivityExecutor.java:59) ~[pega-executor.jar:?]
at com.pega.platform.executor.jobscheduler.internal.ActivityExecutor.executeActivity(ActivityExecutor.java:51) ~[pega-executor.jar:?]
at com.pega.platform.executor.jobscheduler.internal.ActivityProcessor.executeActivity(ActivityProcessor.java:73) ~[pega-executor.jar:?]
at com.pega.platform.executor.jobscheduler.internal.ActivityProcessor.execute(ActivityProcessor.java:59) ~[pega-executor.jar:?]
at com.pega.platform.executor.jobscheduler.internal.ActivityProcessor.run(ActivityProcessor.java:110) ~[pega-executor.jar:?]
at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1381) ~[prprivate-session.jar:?]
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1124) ~[prprivate-session.jar:?]
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1005) ~[prprivate-session.jar:?]
at com.pega.pegarules.session.internal.PRSessionProviderImplForModules.doWithRequestorLocked(PRSessionProviderImplForModules.java:83) ~[prprivate-session.jar:?]
at com.pega.platform.executor.jobscheduler.internal.ActivityProcessor.run(ActivityProcessor.java:101) ~[pega-executor.jar:?]
Can you help me ?
