Pega does not shut down on JBoss EAP 6.3.3
I am facing issue regarding pega shut down -
Pega 7.2 has been deployed as EAR in application server jboss EAP 6.3.3 and OS window server 2012 R2.
Jboss has been configure as a service under Microsoft Windows 2012 R2. Start works fine through service but when you stop the service pega does not stop and service status remain as stopping and there is no error in either pega log or jboss server log.
so it seems there is no stopping signal from service to jboss.
Attached the service_v7.bat which has been used to install the jboss as service through command
service_v7.bat install /startup /name Pega7 /desc "Pega 7 on JBoss Enterprise Application Plattform 6" /config standalone-full.xml
Have any one face similar issue?
Thank you.
Message was edited by: Marissa Rogers - Added Category, moved from Mesh Help
According to redhat, you should use service_v6 for eap 6.3. Not sure that makes difference, but I would like to see the logs to see if your issue is due to pega or not. We are aware of one issue during normal jboss eap shutdown through cli: https://collaborate.pega.com/question/pega-does-not-shut-down-jboss-eap-633
