Proximus
BE
Last activity: 17 May 2021 6:21 EDT
PEGA 8.5.2 - Node Classification & Invalid configuration. Undefined stream provider end point
On a full fresh environment upgrade from 8.2.x to 8.5.2 without any processing, I've set up a node as Search,WebUser,BackgroundProcessing.
It's a fresh install with all stream tables are empty.
The node mentioned above (Search,WebUser,BackgroundProcessing) is complaining with lots of :
StreamServiceException: Invalid configuration. Undefined stream provider end point
for:
[2/10/21 14:32:30:877 CET] 0000009b SystemOut O 2021-02-10 14:32:30,848 [,19,2,3,4,5,6,7,8,9]] [ STANDARD] [ ] [] (w.listener.RetryLoggerListener) ERROR - [pyProcessCaseEvents] Preparing retry 8. Next attempt in 2m on data flow [pyProcessCaseEvents] on stage [InputStage] with affected partitions: [0, 1, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 2, 3, 4, 5, 6, 7, 8, 9]
[2/10/21 14:32:31:865 CET] 0000009b SystemOut O 2021-02-10 14:32:31,844 [,19,2,3,4,5,6,7,8,9]] [ STANDARD] [ ] [ ] (w.listener.RetryLoggerListener) ERROR - [pyBIBatchIndexClassesProcessor] Preparing retry 8. Next attempt in 2m on data flow [pyBIBatchIndexClassesProcessor] on stage [InputStage] with affected partitions: [0, 1, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 2, 3, 4, 5, 6, 7, 8, 9]
and lots of others
Question: on any case with Pega8 we need to have one stream node up & running?
Thank you
Regards
Anthony
for:
and lots of others
Thank you
Regards
Anthony
