PEGA 7.3 Node scope not displaying
What's the possible reason why Node Scope data got deleted and does not refresh.
I've been testing for quite a while, I've changed the Access Group, also added 24 hours to reload if page is older.
Here is the scenario.
There is a Deployment Notification record that holds the messages. On login, base on access group and the start date and end date the notification message should display on top of the dashboard. The data source of the data page is an activity that reads from the deployment message that has one parameter reading from Access Group pyAccessGroup field. When I run the data page using my developer account then the notification gets displayed even for other operators. But after some time, it will not show up. The time when it starts not showing up differs.
