Param.Name syntax in button action
why Param.Name syntax is not supported for certain button actions ? I noticed it for Create Work, Set Value Actions. while it works for Run activity etc.
Harness -> Section with a button. Define Create Work action on click of button.
For Create Work, you give a class name and flow name.If the flow is parameterized, you would see the parameter showing up in the rule form and to populate that if you use Param.Name logic the section itself fails with jsp gragment error. sometimes it doesn't allow you to save the section itself.
Why do you want your flow to be parameterized?
Can you upload a screenshot of your Parameters tab of your section which contains the button?
