ANZ
Last activity: 28 Sep 2018 8:34 EDT
page Down Send Key for Text Adapter Not Working
For me send key for a text adapter is not working.
I have tried with {PGDN}, Page Down key .. No Luck
If I see the Emulator keys documents it says For Page Down I should use "Roll Up" key.
But this option is not present in any send key method.
Any suggestions ?
Cognizant Technology Solutions India PVT Ltd
Hi Manas,
Kindly try @u and let me know is it working or not??
Hi Manas,
Can you try 3 [Numeric Value] and Check Is it work or not?? I mean you have to pass Numeric value 3. SendKeys(3,true)
I found IBM Keyboard Layout Type 5250 Layout
| Roll Up | 3 or PageDown |
ANZ
No Luck :( with "3"
Have tried with {PGDN} as well
Hi Manas,
ANZ
Hi Rohit,
@u worked, How about Page Up?
Hi Manas,
Kindly Try @v for Page Up.
Cigna Corporation
Hi ,
I'm facing similar issue as above.
We have multiple pages for few screens from where I have fetch data. For which we use Page Up manually.
But through automation ,using send keys method with {PGUP} ,@v or by choosing host key PageUp did not work.Its working as if provided any other key like Enter.
Could you please help on this
Sruthi
Sai sunil varma kosuri
Which type of Keybord supported in your MainFrame Application? Or Name of MainFrame Application.
Gayathri Venkatesan
Try SendKeys(3,true)
Cigna Corporation
Hi ,
Thanks for reply.I could find send key in following ways .
- SendKey(1 parameter) :
1.(String key) : Void
2.(HostKeys key) : Void
- SendKey(2 parameters): (HostKeys key, Int32 repeatCount) : Void
I can't try sendkeys(3,true). Is there any other possibility?
