Packaging of App Build Questions, and Rollback Strategies
I have two questions regarding the application development during the CLSA Exam :
(1) Exam can have two types of questions: one built on an existing application, or a stand alone question. What is the recommended way of packaging the answers to the questions ?
(2) Suppose I start coding, and I realize that the approach I am following is not correct. I would then need to delete the rules I have created en masse.
Suppose I want to answer the 4th question of the CLSA Exam, and it is built on an existing application. I was thinking of creating a new Application Rule called CLSA_Q4 (containing one ruleset called CLSA_Q4), and this will have the existing application (if any) as the built-on application. All changes required for 4th question would be on the CLSA_Q4 ruleset.
This approach will completely seperate the build changes from the built on application. And roll back on the rules will be relatively simple: deletion of the ruleset CLSA_Q4 will allow me to roll back to the starting point.
Is there a smarter approach for it ? I went through the prpcServiceUtils description in this link (https://community.pega.com/sites/default/files/help_v82/procomhelpmain.htm#/sys-mgmt/command-line-tool/sm-automated-create-restore-point-tsk.htm) but it is not very clear how this can be run in Linux Lite VM.
