Optimistic locking honors OfflineEnabled function
Is there any resolution for this issue? This is happening on 7.1.9 too.
The behavior has been fixed in Pega 7.2
Since this issue is related check-in logic of pyDefault, it seems to work when deselect “Use check-out” option of ruleset and modify the pyDefault.
I am still concerning if this workaround caused to other functionality of OOTB.
Hi Mounika,
Great! It works on my side.
Thank you for your help,
Jun
You're welcome! Glad to hear that worked for you!
Hello Jun,
Perform a private edit of the pyLockingMode declare expression rule of class Rule-Obj-CaseType and add the following code in the otherwise case as shown in the screen shot.
@java("tools.getProperty(\"pyLockingMode\").getStringValue()")
Let us know the results.
Best Regards,
Mounika
