OOTB function pxDoesHandleExist fails if parameter passed is not a valid handle
The built-in pega function 'pxDoesHandleExist' returns 'true' if the handle exists, as expected.
However, if the parameter passed is 'garbage,' for example - the function fails rather than returning 'false' - with the message "
Class GARBAGE does not exist |
This does not fit with the use case given in the help file - where this function is meant to be used as a precondition for obj-open-by-handle so we can avoid trying to open a nonexistent instance of a rule.
Screenshot attached, please advise.
