One of the decimal column in pega table defined wrongly
Hi Team,
In production one of the Work Table Decimal Column was defined wrongly.
Currently we have a table named ABC(work Table) where column named xyz defined as decimal(18,0)
here xyz was defined with scale of zero where inturn it is not saving decimal values in the column.
We have this column defined in production for almost 6 monthswhich do not have any decimal values in it,where as in blob same property is holding proper values with decimals.
here in blob we have value like 18.67 and in column it is getting saved as 18.
We are planning to change column definition from decimal(18,0) to decimal(12,2).Is there any wizard which can populate column values from blob to available column.
Please let us know is there any way other than deleting the column and creating the column to populate values.
Regards
Anusha
