Blue rose Technolgoies
MY
Last activity: 18 Nov 2016 4:16 EST
Regarding updation of values in one column
How to update the values of one column based on user input.Suppose i have 10 values in one column as 1,2,3....9,10.If I change any value lets say 5 to 1 and 10 to 2.Then the Sequence of 1,2,3,4,5,6,7,8,9,10 should change to 3,4,5,6,1,7,8,9,10,2 and the values should update in DB after the changes was made.
BlueRose Technologies
SE
MY
Hi Prudhvi,
Not only for the above case i.e.,5 and 10.If i change any value it should update accordingly.
BalaRaju
Assuming you are using grid, have you tried disabling the sort option of the column ?
MY
Hi Battacharjee,
Can you please elaborate.On change of any value from the list 1 to 10.Lets say 4 to 1 then the sequence of 1,2,3,4,5,6,7,8,9,10 should change to 2,3,4,1,5,6,7,8,9,10.
thanks,
Balaraju.
Your initial set of data is : 1, 2, 3, 4, 5, 6. 7, 8, 9, 10
You are changing 4 to 1
So new set of data will look like ,
1, 2, 3, 1, 5, 6, 7, 8, 9 , 10
But you want to change it to
So are you also trying to delete the 1 which was initially present at the beginning ?
MY
Exactly,not only for 10 numbers should applicable for N no.of numbers.If i change any number in the sequence lets say from 1 to 100,you change 9 to 3 and 88 to 2 ,then it should be 1,4,5,6,7,8,9,10,3,11,12,.....84,85,86,87,88,2,89,90 .......99,100.
Hi BalaRaju, Could you please share a rela time use case in your project where you are trying to implement this logic.
MY
Please find the attched file.By default the values will be in that Sequence.If user change any value then it should update as in the above scenario.
SE
Hi Balaraju,
Make a count of no of values you changed and their indexes.
Ex: sequence lets say from 1 to 100,you change 9 to 3 and 88 to 2 ,then it should be 1,4,5,6,7,8,9,10,3,11,12,.....84,85,86,87,88,2,89,90 .......99,100.
So, count = 2 and need to change indexes are 9,88. Values which has to replaced are 3,2.
Starting index value which got removed is least value among (3,2) so it is 2.
So, we will start the sequence until its value (2). Ex: 1, ........
From the index value of 2, increment the value with the count. So, sequence will be 1,2+2,3+2,..... which will be 1,4,5,6,...
Then need to change indexes are 9,88. So, when pyForEachcount reaches value of 9 then, get the first value from value which has to get replaced. i.e. 3 and append the value in the sequence. Then count(value needs to be changed) will be reduced to 1 and the next values in the sequence will be incremented by 1 after insertion.
Sequence will be 1,4,5,6,7,8,9,10,3,10+1=11,11+1=12,12+1=13,13+1=14.....
When it reaches index 88, then 2 has to append in the sequence and count will be reduced to 0.
Finally, sequence will be 1,4,5,6,7,8,9,10,3,11,12,.....84,85,86,87,88,2,89,90 .......99,100. This is the logic.
Please let me know if you need any help.
Hi Balaraju,
Hi BalaRaju,
You can use data transform for setting the values as 3,4,5,6,1,7,8,9,10,2.
In the above sequence, we can find the logic as
1) increment every no with value of 2. (1+2 =3, 2+2 =4, 3+2 =5, 4+2 = 6, 5/5 = 1 , 5+2=7, ......,10/5 = 2)
2) Divide with 5, if the count is divisible by 5.
Prudhvi
