Sberbank
RU
Last activity: 1 Jun 2016 9:20 EDT
OnChange event is triggered at the same time attempt to run Flow-action
Hello!
There is such a situation: in the section, there are two properties (let's call them A and B) and the "Submit" button. On event OnChange in property A, property B will computed. By clicking "Submit" is performing validation properties property B. When the user is entering some value into the text field in property A, and, without taking over from the field, hit "Submit" button, OnChange event is triggered at the same time attempt to run Flow-action, and, as a consequence, with validation. Because OnChange processing is not time to change the context, the validation does not work properly and the user leaves the form of a blank field B.
Could you tell me, please, what I can resolve this problem in solution.
I think the problem can be solved by blocking the "Submit" button for the user triggered Pressed Any Key events for the field A. If it is the normal solution, tell me, please, how it can be done.
Message was edited by: Marissa Rogers - Added Category, moved from Mesh Help
