Obj-Save and pxUpdateDateTime
I have a scenario where a property needs to be updated for all the existing work items in production environment.
This has to be done manually by executing an activity.
The activity uses an Obj-Save to save each work item.
However, we observed that Obj-save doesn't update the pxUpdateDateTime property.
Is it recommended to set the pxUpdate properties explicitly or we should avoid setting the pxUpdate properties ?
Nisarg Kothari
