CIBC
Last activity: 1 Jun 2017 11:56 EDT
obj-browse running to error when using "integer property Is Equal intege param number" as the select condition...
Hi, I got error message when I used obj-browse work objects using " .page.property Is Equal param.number". all .page.property and param.number are integer and .page.property has been exposed.
- There was a problem getting a list: code: 0 SQLState: 42883 Message: ERROR: operator does not exist: numeric = character varying
- Hint: No operator matches the given name and argument type(s). You might need to add explicit type casts.
- Position: 162
Same condition is used for report, it works fine.
any suggestion? thanks in advance.
