CGI
Last activity: 31 May 2017 7:08 EDT
As per Obj-Browse method, we can get entire instance of class, but it is not getting?
Obj-Browse method to search instances of one class and copy the entire instances, or specified properties, to the clipboard as an array of embedded pages.
Only properties exposed as columns can be used as selection criteria. However, values of properties that are not exposed as columns, including embedded properties, can be returned.
1 When we are using "Obj-Browse" and calling "pzRDExportWrapper", getting following error "com.pega.pegarules.pub.generator.RuleNotFoundException: Failed to find a 'RULE-OBJ-ACTIVITY' with the name 'PZRDEXPORTWRAPPER' that applies to 'Code-Pega-List'"
2 When we are using "Obj-Open" and calling "pzRDExportWrapper", it is working fine.
Can someone help, what is the issue with Obj-Browse?
Thanks in Advance!
