BPM Company
Last activity: 16 Jul 2018 10:16 EDT
NullPointerException in log when Pega REST service gets a HEAD http message
I configured uptimerobot.com to monitor a REST service that we provide from Pega 7.3.1. They send a GET and HEAD http message each 5 minutes to the service URL. I noticed that the HEAD message generates a NullPointerException in the log and I'd like to avoid that.
I know that Service REST rules support only the GET, POST, PUT and DELETE methods. But I did some testing from Postman and found these responses on the HTTP methods:
Methods that return a 501 Not Implemented status code: PATCH, COPY, LINK, UNLINK, PURGE, LOCK, UNLOCK, PROPFIND & VIEW. These messages will not be registered if you enable service monitoring;
Methods that return a 500 Internal Server Error status code: HEAD & OPTIONS. Only a HEAD message will be registered when service monitoring is enabled.
So my conclusion is that HEAD and OPTIONS are implemented but are not customizable.
My main question is: Is it possible to avoid a NullPointerException with a HEAD message?
See the log with some extra debug logs in. The bold line will be generated with regular log level settings.
2018-07-13 09:04:38,964 [p-apr-8080-exec-1368] [ STANDARD] [ ] [ ] ( internal.services.ServiceAPI) DEBUG <RemovedHostFromLogMessage> - Constructing alert for messageId PEGA0011
2018-07-13 09:04:38,964 [p-apr-8080-exec-1368] [ STANDARD] [ ] [ ] ( internal.services.ServiceAPI) DEBUG <RemovedHostFromLogMessage> - Enabling alert for messageId PEGA0011
2018-07-13 09:04:38,964 [p-apr-8080-exec-1368] [ STANDARD] [ ] [ ] ( internal.services.ServiceAPI) INFO <RemovedHostFromLogMessage>|Rest|Abillity|API|customers - Processing service request...
2018-07-13 09:04:38,965 [p-apr-8080-exec-1368] [ STANDARD] [ ] [ ] ( internal.services.ServiceAPI) DEBUG <RemovedHostFromLogMessage>|Rest|Abillity|API|customers - entering postLockCleanup()
2018-07-13 09:04:38,965 [p-apr-8080-exec-1368] [ STANDARD] [ ] [ ] ( internal.services.ServiceAPI) ERROR <RemovedHostFromLogMessage>|Rest|Abillity|API|customers - Rest service [Abillity][API][customers] failed::java.lang.NullPointerException
2018-07-13 09:04:38,965 [p-apr-8080-exec-1368] [ STANDARD] [ ] [ ] ( internal.services.ServiceAPI) DEBUG <RemovedHostFromLogMessage> - leaving postLockCleanup()
Hi.
2 questions:
1. Why you are trying to use HEAD if you "know that Service REST rules support only the GET, POST, PUT and DELETE methods"?
2. What you cannot achieve using just GET method that made you to use HEAD instead?
