ING
Last activity: 10 Jul 2025 9:55 EDT
Not Showing the ID(Key Column in Data Type) from Data Designer while trying Edit /Add new records
I am Having a Datatype with ID (ex: 1, 2,..) as a class key and total of around 70 records in that Datatype.
recently, I am observing that for some of the records I am not seeing any Id for some of the records.
When I tried to add a new records not able see the ID column, but all other columns are showing and when I try to update the record (for which ID is showing) just after clicking on that records the ID is disappearing.
as a work around I tried following
1. checked xml of records, the ID values is available in its xml form
2. run the Report Definition, here also able to see the ID in results
3. Run the Data Page which is Sourcing the same Report Definition (mentioned in 2, but here on the results page I am not able to see the ID (for those records which are not showing the ID in Data Designer).
it's the behavior in Test Environment only, in Dev it is working fine.
@SindhuN17376320
In the DataTableEditorReport of the data type class, check if the hide column checkbox is checked or not.
