Tata Consultancy Services
Not able to process the posts from twitter using Dataflow which contains Twitter Dataset and text analyzer. Facing the issue that Data flow getting failed with status “Completed with failures” on Decisioning: Data Flows landing page.
I have created Data flow that is calling twitter data set and next text analyzer.
But I am facing below issues:
- Twitter data set with Stream option selected and If I run the data flow from the action button of data flow rule, it is creating the test model on “Decisioning: Data Flows” landing page and processing the comments posted on twitter but after some time this test model is getting deleted.
- Twitter data set with Stream/Playback and If I created data flow model from “Decisioning: Data Flows” landing page or from Activity using Dataflow-execute Method, it is creating model but not processing any records from twitter. And Data flow model getting failed with status “Completed with failures” on Decisioning: Data Flows landing page after some time.
- Twitter data set with Playback Option and If I run the data flow from the action button of data flow rule, getting failed with message “since it exceeds the max number of failed record, which is currently set to 0”
Note I have changed max number of failed record count to 1000 using dynamic system setting, but still getting the same issue.
Please suggest me if anyone knows that what could be the reasoned that I am not able to process the records from twitter and reason for failing the model with status as “Completed with Failures”.
Please find the attached screen shots for the issue.
