Need information regarding "Cancel" action
I have this one question regarding "Cancel" action that we use in a button or in other UI elements.
Let's say, I am launching one harness from one section(the Section is in one flow action) through a button. Now I am using one button inside that harness where I am using "Cancel" action in order to return to the parent section. The harness I am using is an Overlayed one. So, while I am trying to get back to the parent section by clicking on the Cancel button, I am not being able to get back to the parent section. Instead it's navigating back to somewhere else.
Can anyone please clarify why is this happening and how can i get the desired parent section rule by clicking on the Cancel button.
Hi Soumya,
Thanks for posting your query to PSC.
As per my understanding you are trying to launch a Harness onclick of a button and that harness contains a cancel action button. So if I am not wrong on click of that cancel button your requirement is to come back to the parent section.
So to achieve that can you make the target of the Harness launched as Pop-up Window as shown in the below screen shot. So that when you click on cancel button of the launched harness, the pop-up window will be closed and so you will return to the work object.
Do let me know if I misunderstood your requirement or the suggested solution doesnt help you.
Chinmai Sravanthi.
