NTT Data
NTT Data
NTT Data
Posted: Jun 18, 2018
Last activity: Jun 19, 2018
Last activity: 19 Jun 2018 17:14 EDT
Need Delimiter as "&" or "%" in BIX Extract files
Hello Team,
Could you please help me how to put "&" or "%" as a Delimiter in BIX Extract files. We are not running the files in Command Line
Note: We have selected CSV format file.
Are you running the extracts through an agent since you are not running from the command line? Assuming you are running using an agent running pxExtractDataWithArgs you would pass this as a command line parameter to the activity.
You can change the delimiter with the -l property
https://community.pega.com/system/files/pdfs/BIX%207.3.1%20User%20Guide.pdf
-l <delimiter> Specify a user-defined character as the delimiter separating extracted data.
The following characters are not available for use as delimiters, as they signify other things to BIX:
l Double-quote (“)
l Asterisk (*)
l Double-quote (“)
l Asterisk (*)
l Hyphen (-)
BIX also does not support multi-line delimiters. If the delimiter length is greater than 1, then BIX reports an
error.
