Mutliselect Control sourced by Parameter D_page
I have a requirement like cascading dropdown implementation,
Based on the reporting unit(Multiselect) Values , the Team Members (Multiselect) value should be displayed .
getting below error
Invalid clipboard stream detected in module (unspecified). Reason: (unspecified) |
While Hard coding the parameters directly we are getting the teammembers muliselect but when it dynamically passsing through a param the paramater is setting to null and getting all the results for the multiselect. this error is seen in Tracer on UI.
This happening when we are passing more than one value as param , i:e while selecting more than 1 reporting unit, the team memebers multiselect is getting below error.
Suggest me If you have any idea about this error
