Maximum URL length
We wanted to know the maximum length of the URL allowed by Pega.
Customer wants to pass a number of fields as URL parameters and they want to know how much data they can pass.
Until Pega v7.1.6, I don't think Pega has the limitation of the maximum URL length, it depends on the webserver in which your PRPC is deployed and also based on the browser used the maximum length of URL might vary.
May be others can reply if they had set any limitation in the later releases.Hope it might be helpful to you.
Regards
Mahesh
Hi MITTS,
Which Pega 7 release you are working on?
In Pega 7.1.8 and Pega 7.1.9, I am aware of the following problem.
The size of the url is exceeding the default GET limit of 8190 characters and this causes problem. Pega has issued hotfix to deal with it.
If you have encounter such issue, please let us know.
Susan
