The Toronto Dominion Bank
Last activity: 29 May 2017 10:37 EDT
Maximum open cursors exceeded: PEGA_DATA_SPPC_DATA_UNIQUEID
We are getting the below issue in our UAT environment. Its intermittent, and only happening in UAT environment. Please check the attached screenshot as well.
Unable to Obtain Unique ID: Problem encountered executing a stored procedure: code:1000 SQLState: 72000 Message: ORA- 01000: maximum open cursor exceeded
I have already checked the cursor configuration and its exactly same in all other environment. But the problem is happening in one environment only.
There is no mismatch in JDBC driver and DB version as well. Restarting the server solves the problem for some time and it comes again.
I have also followed up on other posts as well but most of them saying same thing to check the driver. Dont know what is causing the issue.
***Updated by Moderator: Marissa to add SR Details***
Hello!
On reviewing the corresponding SR, we see that the issue was resolved after upgrading to Pega 7.2.2.
Thank you,
what is your pega version?
PEG
Also, can you please confirm which database driver you are using?
Pega version is 7.1.5 and driver is ojdbc6
Thanks for the info. Can you attach the log? Would like to review the complete error stack.
2017-04-11 17:21:17,979 [ PegaRULES-Batch-3] [ STANDARD] [ PegaRULES:07.10] ( internal.async.AgentQueue) ERROR - Problem queue Pega-ProcessEngine #3: System-Queue-FlowDependency.pzProcessFlowDependency will restart in 180000 ms
2017-04-11 17:21:43,820 [ PegaRULES-Batch-3] [ STANDARD] [ PegaRULES:07.10] (l.access.ConnectionManagerImpl) ERROR - Not returning connection 102340838 for database "pegadata" to the pool as it previously encountered the following error
User ID: System
Last SQL: {call PEGA_DATA.sppr_sys_reservequeueitem_b ( ?, ?, ?, ?, ?, ?, ?, ?, ?, ?) }
java.sql.SQLException: ORA-01000: maximum open cursors exceeded
ORA-06512: at "PEGA_DATA.SPPR_SYS_RESERVEQUEUEITEM_B", line 138
ORA-06512: at line 1
User ID: System
at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:445)
at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:396)
at oracle.jdbc.driver.T4C8Oall.processError(T4C8Oall.java:879)
at oracle.jdbc.driver.T4CTTIfun.receive(T4CTTIfun.java:450)
at oracle.jdbc.driver.T4CTTIfun.doRPC(T4CTTIfun.java:192)
at oracle.jdbc.driver.T4C8Oall.doOALL(T4C8Oall.java:531)
at oracle.jdbc.driver.T4CCallableStatement.doOall8(T4CCallableStatement.java:204)
at oracle.jdbc.driver.T4CCallableStatement.executeForRows(T4CCallableStatement.java:1041)
at oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(OracleStatement.java:1329)
at oracle.jdbc.driver.OraclePreparedStatement.executeInternal(OraclePreparedStatement.java:3584)
at oracle.jdbc.driver.OraclePreparedStatement.execute(OraclePreparedStatement.java:3685)
at oracle.jdbc.driver.OracleCallableStatement.execute(OracleCallableStatement.java:4714)
at oracle.jdbc.driver.OraclePreparedStatementWrapper.execute(OraclePreparedStatementWrapper.java:1376)
at org.jboss.jca.adapters.jdbc.CachedPreparedStatement.execute(CachedPreparedStatement.java:297)
at org.jboss.jca.adapters.jdbc.WrappedPreparedStatement.execute(WrappedPreparedStatement.java:404)
at com.pega.pegarules.data.internal.access.DatabasePreparedStatementImpl.execute(DatabasePreparedStatementImpl.java:990)
at com.pega.pegarules.data.internal.access.DatabaseImpl.list(DatabaseImpl.java:6194)
at com.pega.pegarules.data.internal.access.DatabaseImpl.executeRDB(DatabaseImpl.java:6664)
at com.pega.pegarules.data.internal.access.DatabaseImpl.executeRDB(DatabaseImpl.java:6620)
at com.pega.pegarules.data.internal.access.DatabaseImpl.executeRDB(DatabaseImpl.java:6601)
at com.pega.pegarules.session.internal.async.agent.QueueManagerImpl$QueueIteratorImpl.next(QueueManagerImpl.java:1951)
at com.pega.pegarules.session.internal.async.agent.QueueManagerImpl$QueueIteratorImpl.next(QueueManagerImpl.java:1874)
at com.pega.pegarules.session.internal.async.agent.QueueProcessor.execute(QueueProcessor.java:454)
at com.pega.pegarules.session.internal.async.BatchRequestorTask.run(BatchRequestorTask.java:884)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1192)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:930)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:829)
at com.pega.pegarules.session.internal.async.BatchRequestorTask.run(BatchRequestorTask.java:617)
at com.pega.jsr166backport.java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:991)
at com.pega.jsr166backport.java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:532)
at java.lang.Thread.run(Thread.java:745)
2017-04-11 17:21:43,820 [ PegaRULES-Batch-3] [ STANDARD] [ PegaRULES:07.10] ( async.agent.QueueManagerImpl) ERROR - Problem with browse of System-Queue-ServiceLevel
com.pega.pegarules.pub.database.DatabaseException: There was a problem getting a list: code: 1000 SQLState: 72000 Message: ORA-01000: maximum open cursors exceeded
SQL Inserts: <PEGA_DATA.pr_sys_queue_sla> <System-Queue-ServiceLevel> <Pega-ProCom:ServiceLevelEvents> <Scheduled> <c1b8c841417ef4862c3be3c648559237> <> <20170411T212143.816 GMT> <true> <> <(OUTPUT PARAMETER)>
Caused by SQL Problems.
Problem #1, SQLState 72000, Error code 1000: java.sql.SQLException: ORA-01000: maximum open cursors exceeded
at com.pega.pegarules.data.internal.access.ExceptionInformation.createExceptionDueToDBFailure(ExceptionInformation.java:167)
at com.pega.pegarules.data.internal.access.DatabaseImpl.list(DatabaseImpl.java:6271)
Caused by: java.sql.SQLException: ORA-01000: maximum open cursors exceeded
... 14 more
Please create a SR with GCS, this is likely a potential defect.
As Kevin suggested, you may go ahead and create an SR with the support team. Once you do that, please let us know the SR number so that we can tag it to the thread for the benefit of the engineer.
Thanks!
Hello!
Thank you,
