Lantiqx
Last activity: 9 Sep 2019 6:22 EDT
Mapto and Mapfrom utility functions usage in Integration
Hello Experts,
I would like get clarified on below as nowhere I can get clear information although I can use the artifact which is the point of this post without understanding.
REST INTEGRATION ---> Service-REST:
Incoming Request --> JSON format
Outgoing Response --> JSON format
How to map incoming JSON request as part of POST method request tab?
[Same sort of question applies to response tab Map From and Map From Key]
Map to: ____
Map to key: _____
Below (at the bottom) is what has been explianed in Pega help documents where I feel contradiction between Clipboard and JSON usage for Map to field.
1. Why the label Map To is used in request tab when Map to Key is going to be a page/pagelist property on Clipboard?
The label can be Map From where we can get the incoming data format which is JSON.
2. If Map To label is justified as where to we need to map incoming data, then Clipboard will be the choice to opt given that we want to map incoming JSON data to Clipboard.
In this case, why should I give JSON as the selected option for Map To as per the explanation given below in pega help document?
Hello Experts,
Map to: ____
Map to key: _____
| Map To | Specify the destination or the type of destination for the value in the Pega Platform :
