State Farm
Last activity: 29 Jan 2021 9:16 EST
Losing Index Key Property on data cell in Loop with 2 paths
I have a webpage table that can have results in 2 locations. Using some logic I've created 2 possible paths for the logic flow. Once it determines which path to take, there is a loop (Location1 Loop, and a Location2 Loop). It will always end up in one or the other successfully.
The problem I am having is that the Index key property will show up correctly and let me wire it for only one loop line. As soon as I connect the second loop, the Index disappears from the first loop. I can repeatedly disconnect and reconnect, but cannot get both to stay in the automation. This is preventing me from looping through the data to find the portion I need when the logic takes the 2nd path, since the Index will not stay.
In the attached image, I've highlighted where the Index I am trying to use needs to be located in both lines.
Oddly, we had the index working in the automation prior to making a minor update in another part of the page. The Indexing disappeared during the unrelated changes and doesn't want to come back.
Any help you can give is greatly appreciated!
