Last activity: 28 Apr 2023 18:07 EDT
Long running (Stale) Thread causing system resart
Hi team..
Can I get more information regarding this SR. We are facing the same issue. which configuration is this article pointing to? Is it DSS or an option exposed on rule form?
https://community.pega.com/node/2396651
Alerts for queue processor (QP) items which took more than 15 minutes to run could result in the system marking the node as 'unhealthy'. In environments with Pega Health Check enabled, this would shut down the node gracefully. It was not possible to change this default as it was hardcoded. In order to support systems that may have custom processes that run beyond 15 minutes, a a new setting has been exposed that allows configuration of the interval after which a node with long-running queue processor is marked as unhealthy and is restarted. By default this remains 900000 milliseconds / 900 seconds / 15 minutes, but it may be adjusted up to 24 hours to avoid premature node shutdown. The stale thread detection mechanism will take that setting into account and use the provided value or default to 15 minutes if the value was not provided. In addition, the threshold's units in the UI have been changed from ms to seconds.
Resolved in Product Version: 8.3.6
SR/INC: 172675
Issue: 649451
