Log-Message method resulst java.lang.throwable exception in AES
I have and activity containing Log-message method.
Here the logging level is being set to Error. During execution , this step results java.lang.Throwable exception in AES. I have tried to change logging level to Debug/Info/warn and ran through the flow without any exceptions. I.e Error logging level setting is the source of this exception.
I have cross checked with other activities in my application which contains Log-Message step and logging level is set to Error. Faced the same exception during execution.
I am not able to determine the issue when the logging level is set to Error. Could anyone help
