Local development environment minimum configuration
If we are to use a local develop/test environment , i.e. one environment per developer/tester, what would be the minimum configurations required on a environment.
We are using Pega 7.1.9 on Weblogic-Oracle setup.
The installation guide recommends 4GB heap for weblogic and 8GB for database.
Can this be reduced further without 'trial and error' method?
Muthu
the recommendation suggested by us is optimum one . With less heap size, it might incur performance issue.
On a separate note, I am bit curious, why you want separate system for each users ? Is it for training / hands on ?
