Large LOB Segment impacting DB Performance
In a partner-led performance test, we are seeing the PZPVSTREAM column for the table, PCA_WORK, grow to almost 10 GB after 3 hours of running the test for simulating 6,000 users.
The AWR Report for the DB is indicating a large amount of Buffer Busy Wait signals as well as direct path writes. Here is an excerpt from the AWR report showing the Buffer Busy Wait signals:
The entire AWR Report is also attached (html file).
I realize that PZPVSTREAM column will likely grow to be very large in such a performance test, but 10 GB sounds like a little much. Are there any database tuning measures that should be implemented in this case?
The partner did find a document on the PDN (https://pdn.pega.com/documents/db-lob-sizing-v54) which suggested that they create a separate tablespace for the LOB segment with a larger block size and to set the chunk size equal to the average BLOB size. The document applies to version 5.4 and I was not sure if it is still applicable to Pega 7.
Does anyone have experience with LOB sizing that can chime in?
Thanks in advance.
***Updated by moderator: Lochan to close post***
