Cognizant
Last activity: 7 Aug 2023 10:32 EDT
KYC Types missing after 8.7.4 upgrade from 8.4.3
After upgrade from Pega 8.4.3 to Pega 8.74, we observed KYC type insances are not available and also not present in new kyc_type table which is new mapping table for Rule-PegaKyc-Type class. But when we change this mapping to pr4_rule then we could see all KYC instances in upgraded environment.
Anyone experienced this issue and any known solution
Thanks in advance
@SrikanthN2482
Did update was successful? Have you noticed any errors in logs during the update?
Have you followed the same order as documented in the update guide to import the applications? If you have imported application in random order then probably could cause the problem. Reviewing the update logs will be helpful.
https://docs-previous.pega.com/pega-client-lifecycle-management-and-kyc-87-update-guide/87/importing-application
KYC rules are stored in the platform table pr4_rule. The update to 8.6 automatically migrates the KYC rules into new dedicated database tables (kyc_type, kyc_supporting_evidence) that provide more flexibility to the solution.
https://docs-previous.pega.com/pega-client-lifecycle-management-and-kyc-feature-adoption/87/pega-client-lifecycle-management-and-kyc-87-post-update-tasks
Completed update guide
https://docs-previous.pega.com/pega-client-lifecycle-management-and-kyc-87-update-guide/87/pega-client-lifecycle-management-and-kyc-87-update-guide
