Anthem Blue Cross Blue Shield
Last activity: 18 Mar 2021 2:49 EDT
Kafka Dataset not able to consume data.
Hello all,
We are using kafka dataset to consume data to our system. Then I am doing test connectivity I am able to connect from the kafka dataset configurations.
But, when external put some files on the kafka topic we were not able to consume records. Dataflow is showing in progress but, I am not able to see any input records. I can not see any errors in logs as well. please help me to resolve this issue.
I have enabled following loggers to debug.
com.pega.dsm.dnode
org.apache.kafka
Thanks.
***Edited by Moderator Marissa to move from Pega Academy to Pega Support Community; update platform capability tags***
Likes (1)
Kevin Nanayakkara -
What is the status of stream service in stream landing page(Decisioning-->infrastructure-->services--->stream) ?
Meanwhile you may review the below link.
Thank You,
Bank Of America
we are seeing some issue with data-set execution #Any insights on this ...
2020-05-21 05:48:12,503 [ WebContainer : 4] [ STANDARD] [ ] [XXXXXXXX:02.06.01] (XXX_XXXX_XXXX_Data_TrADS.Action) ERROR ah-hhhhhhhhhhhhhhhhhhh.com|XX.XXX.XXX.XX user- [SystemT][PublishToKafka][Error] ** Java Exception: java.lang.RuntimeException: com.pega.dsm.dnode.api.BatchRecordException
java.lang.Throwable
at com.pegarules.generated.activity.ra_action_publishtokafka_f07b8373cee9ef3a9627099e5703b239.step3_circum0(ra_action_publishtokafka_f07b8373cee9ef3a9627099e5703b239.java:387) ~[?:?]
at com.pegarules.generated.activity.ra_action_publishtokafka_f07b8373cee9ef3a9627099e5703b239.perform(ra_action_publishtokafka_f07b8373cee9ef3a9627099e5703b239.java:108) ~[?:?]
at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3597) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.mgmt.Executable.invokeActivity(Executable.java:10845) ~[prprivate.jar:?]
at com.pegarules.generated.activity.sh_action_resendtotrads_86e83064ed62dbab22c1f3d36d24f577.step6_circum0(sh_action_resendtotrads_86e83064ed62dbab22c1f3d36d24f577.java:308) ~[?:?]
at com.pegarules.generated.activity.sh_action_resendtotrads_86e83064ed62dbab22c1f3d36d24f577.perform(sh_action_resendtotrads_86e83064ed62dbab22c1f3d36d24f577.java:94) ~[?:?]
at com.pega.pegarules.session.internal.mgmt.Executable.doAction(Executable.java:3330) ~[prprivate.jar:?]
at com.pegarules.generated.activity.ra_action_pyrunrecordexecute_f7d1e1c1513eef165c7ecbe136f3addd.step2_circum0(ra_action_pyrunrecordexecute_f7d1e1c1513eef165c7ecbe136f3addd.java:249) ~[?:?]
at com.pegarules.generated.activity.ra_action_pyrunrecordexecute_f7d1e1c1513eef165c7ecbe136f3addd.perform(ra_action_pyrunrecordexecute_f7d1e1c1513eef165c7ecbe136f3addd.java:88) ~[?:?]
at com.pegarules.generated.activity.ra_action_pzrunrecordexecute_c38281e0bb63f7c4aab88814460c8435.step11_circum0(ra_action_pzrunrecordexecute_c38281e0bb63f7c4aab88814460c8435.java:1027) ~[?:?]
at com.pegarules.generated.activity.ra_action_pzrunrecordexecute_c38281e0bb63f7c4aab88814460c8435.perform(ra_action_pzrunrecordexecute_c38281e0bb63f7c4aab88814460c8435.java:246) ~[?:?]
at com.pega.pegarules.session.internal.mgmt.base.ThreadRunner.runActivitiesAlt(ThreadRunner.java:646) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.mgmt.PRThreadImpl.runActivitiesAlt(PRThreadImpl.java:481) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.engineinterface.service.HttpAPI.runActivities(HttpAPI.java:3414) ~[prprivate.jar:?]
at com.pega.pegarules.session.external.engineinterface.service.EngineAPI.processRequestInner(EngineAPI.java:399) ~[prenginext.jar:?]
at sun.reflect.GeneratedMethodAccessor147.invoke(Unknown Source) ~[?:?]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:55) ~[?:1.8.0]
at java.lang.reflect.Method.invoke(Method.java:508) ~[?:1.8.0]
at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1338) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1075) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:930) ~[prprivate.jar:?]
at com.pega.pegarules.session.external.engineinterface.service.EngineAPI.processRequest(EngineAPI.java:336) ~[prenginext.jar:?]
at com.pega.pegarules.session.internal.engineinterface.service.HttpAPI.invoke(HttpAPI.java:854) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl._invokeEngine_privact(EngineImpl.java:331) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.invokeEngine(EngineImpl.java:274) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.engineinterface.etier.ejb.EngineBean.invokeEngine(EngineBean.java:225) ~[prprivate.jar:?]
at sun.reflect.GeneratedMethodAccessor92.invoke(Unknown Source) ~[?:?]
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:370) ~[prbootstrap-7.3.1-218.jar:7.3.1-218]
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:411) ~[prbootstrap-7.3.1-218.jar:7.3.1-218]
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:224) ~[prbootstrap-api-7.3.1-218.jar:7.3.1-218]
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingException(AppServerBridgeToPega.java:246) ~[prbootstrap-api-7.3.1-218.jar:7.3.1-218]
at com.pega.pegarules.internal.etier.ejb.EngineBeanBoot.invokeEngine(EngineBeanBoot.java:168) ~[prbeans.jar:7.3.1-218]
at com.pega.pegarules.internal.etier.interfaces.EJSLocalStatelessEngineBMT_f2439d86.invokeEngine(Unknown Source) ~[prbeans.jar:7.3.1-218]
at com.pega.pegarules.priv.context.JNDIEnvironment.invokeEngineInner(JNDIEnvironment.java:278) ~[prpublic.jar:?]
at com.pega.pegarules.priv.context.JNDIEnvironment.invokeEngine(JNDIEnvironment.java:223) ~[prpublic.jar:?]
at com.pega.pegarules.web.impl.WebStandardImpl.makeEtierRequest(WebStandardImpl.java:678) ~[prwebj2ee.jar:?]
at com.pega.pegarules.web.impl.WebStandardImpl.doPost(WebStandardImpl.java:394) ~[prwebj2ee.jar:?]
at sun.reflect.GeneratedMethodAccessor143.invoke(Unknown Source) ~[?:?]
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:273) ~[prbootstrap-api-7.3.1-218.jar:7.3.1-218]
at com.pega.pegarules.internal.web.servlet.WebStandardBoot.doPost(WebStandardBoot.java:129) ~[prbootstrap-api-7.3.1-218.jar:7.3.1-218]
at com.pega.pegarules.internal.web.servlet.WebStandardBoot.doGet(WebStandardBoot.java:100) ~[prbootstrap-api-7.3.1-218.jar:7.3.1-218]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:687) ~[javax.j2ee.servlet.jar:?]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790) ~[javax.j2ee.servlet.jar:?]
at com.ibm.ws.webcontainer.servlet.ServletWrapper.service(ServletWrapper.java:1235) ~[com.ibm.ws.webcontainer.jar:?]
at com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest(ServletWrapper.java:779) ~[com.ibm.ws.webcontainer.jar:?]
at com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest(ServletWrapper.java:478) ~[com.ibm.ws.webcontainer.jar:?]
at com.ibm.ws.webcontainer.servlet.ServletWrapperImpl.handleRequest(ServletWrapperImpl.java:179) ~[com.ibm.ws.webcontainer.jar:?]
at com.ibm.ws.webcontainer.filter.WebAppFilterManager.invokeFilters(WebAppFilterManager.java:1124) ~[com.ibm.ws.webcontainer.jar:?]
at com.ibm.ws.webcontainer.servlet.CacheServletWrapper.handleRequest(CacheServletWrapper.java:82) ~[com.ibm.ws.webcontainer.jar:?]
at com.ibm.ws.webcontainer.WebContainer.handleRequest(WebContainer.java:963) ~[com.ibm.ws.webcontainer.jar:?]
at com.ibm.ws.webcontainer.WSWebContainer.handleRequest(WSWebContainer.java:1817) ~[com.ibm.ws.webcontainer.jar:?]
at com.ibm.ws.webcontainer.channel.WCChannelLink.ready(WCChannelLink.java:382) ~[com.ibm.ws.webcontainer.jar:?]
at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleDiscrimination(HttpInboundLink.java:465) ~[com.ibm.ws.runtime.jar:?]
at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleNewRequest(HttpInboundLink.java:532) ~[com.ibm.ws.runtime.jar:?]
at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.processRequest(HttpInboundLink.java:318) ~[com.ibm.ws.runtime.jar:?]
at com.ibm.ws.http.channel.inbound.impl.HttpICLReadCallback.complete(HttpICLReadCallback.java:88) ~[com.ibm.ws.runtime.jar:?]
at com.ibm.ws.ssl.channel.impl.SSLReadServiceContext$SSLReadCompletedCallback.complete(SSLReadServiceContext.java:1833) ~[com.ibm.ws.runtime.jar:?]
at com.ibm.ws.tcp.channel.impl.AioReadCompletionListener.futureCompleted(AioReadCompletionListener.java:175) ~[com.ibm.ws.runtime.jar:?]
at com.ibm.io.async.AbstractAsyncFuture.invokeCallback(AbstractAsyncFuture.java:217) ~[com.ibm.ws.runtime.jar:?]
at com.ibm.io.async.AsyncChannelFuture$1.run(AsyncChannelFuture.java:205) ~[com.ibm.ws.runtime.jar:?]
at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:1909) ~[com.ibm.ws.runtime.jar:?]
Updated: 18 Mar 2021 2:49 EDT
Verizon
Hi Sharath,
Did you find the root cause?
we are facing similar issue, could you provide details?
Thanks!
Rajasri
