JBOSS / Oracle PRPC platform preparation
The installation for JBOSS / Oracle, suggests that the NLS_LENGTH_SEMANTICS parameter should be set to ‘CHAR’ in order to support localization. However, Oracle strongly recommends that you do NOT set the NLS_LENGTH_SEMANTICS parameter to CHAR in the instance or server parameter file. This may cause many existing installation scripts to unexpectedly create columns with character length semantics, resulting in run-time errors, including buffer overflows.
More information here: https://docs.oracle.com/database/121/REFRN/GUID-221B0A5E-A17A-4CBC-8309-3A79508466F9.htm#REFRN10124
Is this an optional configuration for Pega Installation ? Can we keep the value of NLS_LENGTH_SEMANTICS to the default value of ‘BYTE’ ?
***Moderator Edit: Vidyaranjan | Tagged SRExists***
