JBoss EAP 6.4.x  with Java 8
I need a clarification about the following question regarding the support of Red Hat JBoss EAP 6.4.x (using Java 7 or 8).
It is not clear if it is also supported version 8, though it is wrote so on page 6 of the Pega 7.2 platform-support-guide.pdf.
Because then on page 12 there is this note:
11. JBoss does not bundle a JVM in its application. Pega recommends Oracle Java 7, at
the latest level ( 'unless it is Specifically That Stated That level does not run with Pega
7). See Note # 2 above for information on the latest Oracle Java 7 levels.
So the question is:
is JBoss EAP 6.4.x with Java 8 supported or not ?
Thank You
