cognizant
Last activity: 3 Apr 2017 2:57 EDT
Its Urgent :Load balancer to make the service routed to particular node
Hi all,
I have a requirement where i built a service activity.
The service activity use requestor ID to display some popup kind of in client browser(requestor).
Everything works fine when there is a single node. But for multi-node environment it doesnt work since requestor ID and Sevice run will not be in same node.
Say like i have node A, node B, Agent logged in (requestor) node B.
Is there a way like when a service request comes in, Service using node B should process the request not node A.
The incoming request can contain node ID as well as Requestor ID.
can we make use of load balancer functionality to achieve this.
Using CPM 7.1.3 over Pega 7.1.8
Prem
