Techmahindra
Last activity: 4 Dec 2018 4:02 EST
Issue with Re-record the Unit Test Case
Pega 7.2.1
Issue: Getting error: Because the test case’s RuleSet has check-out enabled, you must check out XXXXRule before re-recording it. Click here to Open the Test Case.
Steps to Reproduce:
1 Go to Designer studio>Application>Automated Unit Testing>Automated Unit Tests.
2 Under Show, select Unit Test Cases.
3 Right click any row having "Recorded For" Activity, select "Re-record".
4 Getting error: Because the test case’s RuleSet has check-out enabled, you must check out XXXXRule before re-recording it. Click here to Open the Test Case
5 When I "click here", It will open new window, which shows xml with Delete button. It should show Test case Form or Harness. Show "Inputs" and "Results" and "History" tabs.
Query: How can I check-out the rule? When it is opening in new window, which shows xml with Delete button. It should show Test case Form or Harness. Show "Inputs" and "Results" and "History" tabs.
Please guide. Thanks in Advance.....
