The issue of Installing Pega Plattform Personal Edition
Hi,all
Unable to install Pega Personal Edition 7.3.
Please tell the reason why not install...
* OS:Windows 10
* I've tried to install while being off Firewall, but not completed.
Error log:
BUILD FAILED
C:\Users\(my name)\Desktop\115490_PE7.3 (1)\pegaGuiInstallerTemp0\build.xml:164: Unable to connect to database within 15 seconds.
Total time: 1 minute 1 second
org.tp23.antinstaller.InstallException: Use logs to find the cause, then correct and run again
at org.tp23.antinstaller.runtime.exe.AntLauncherFilter.exec(AntLauncherFilter.java:90)
at org.tp23.antinstaller.runtime.ExecInstall.exec(ExecInstall.java:87)
at org.tp23.antinstaller.selfextract.SelfExtractor.main(SelfExtractor.java:398)
Caused by: org.tp23.antinstaller.InstallException: Use logs to find the cause, then correct and run again
at org.tp23.antinstaller.runtime.exe.AntLauncherFilter.exec(AntLauncherFilter.java:80)
... 2 more
--- Nested Exception ---
Hi,all
* OS:Windows 10
Error log:
BUILD FAILED
... 2 more
Output Log:
Unable to connect to d...atabase -- will retry in 1 second...
Unable to connect to database -- will retry in 1 second...
