Integrating a angular application in pega
Hi ,
Our business wants to use an angular+java application with workflow also in there to be embedded in already running pega application. Need assistance to achieve this ask.
@NikitaG7 please do a key word search for 'Angular' in our documentation.
To embed an Angular+Java application into an existing Pega application, you can use Pega's open APIs and connectors. Pega provides an orchestration layer with pre-built components to accelerate the integration of user experiences developed on popular front-end frameworks like Angular. You can use Pega DX APIs to provide elegant and powerful experiences when plugging Pega-developed workflows into front-end customer-facing channels. For the Java part, you can use Pega's Java integration capabilities to call Java methods directly from your Pega application. However, extreme customization of Pega is likely to cause many problems in both the short and long term, and upgrading could be a nightmare. It's recommended to leverage Pega's out-of-the-box features as much as possible.
POC on Pega UI
Using AngularJS in Pega
Angular implementation with Pega 7.2
POC on Pega UI
Pega Paves Path to Seamless Self-Service Experiences with New Embedded Workflow Integrations
Implementing case types > Step1: Identify the UI framework
