Installing Pega 8.4 on Google Cloud
I'm attempting to install Pega 8.4 on Google Cloud using the following guide (https://cloud.google.com/solutions/deploying-pega-platform-using-compute-engine-and-cloud-sql) however, the install is failing with the following error:
"Encountered a database problem when attempting to load jar onto PostgreSQL: ERROR: relation "sqlj.jar_repository" does not exist"
On investigation the sqlj schema has not been created. When I try to try this manually using the install.sql script in the resource folder a get a permissions error on the database:
"ERROR: permission denied for language c SQL state: 42501"
This seems to be due to the user not having superuser rights, which Google address they do not give for the CloudSQL instances.
Has anyone else had this issue or found a solution?
