Importing of Treatments and Actions are not working for me
I've tried to import actions and treatments into the CDH content. Whenever I map the files in it shows 0 rows added or updated and 0 errors.
Not sure what else to do other than create them manually.
@LesM6735 , there is too little information here to help. Please make sure the template you are using for the actions/treatments you are importing is valid. I suggest you run an export first, to establish the structure of the file and then use that file as the basis to update with whatever actions/treatments you need and then upload that. If this does not help, consider raising a support incident with Pega.
