AIG
Last activity: 23 May 2016 4:32 EDT
If this error on log means slowness to the application
Hi the user reported slow performance and almost system hung up.
we check to see the logs to find the below error .Any idea what is this about ? why it happens ?
posted transaction id '9e4984f5d63a0ea076051503146c8161' for frame 'pyWorkPage' DOES NOT match record '211093964c993cedccf6be7919f1464
please clarify with details,.
ERROR: posted transaction id '9e4984f5d63a0ea076051503146c8161' for frame 'pyWorkPage' DOES NOT match record '211093964c993cedccf6be7919f14643'
2016-05-06 14:28:30,608 [read.pool t=009c3398] [ STANDARD] [ MLRCORE:01.01.01] ( mgmt.base.ThreadUITransaction) ERROR mlr.aig.net|XX.XX.XXX.XX 1059835 - ERROR: posted transaction id '9e4984f5d63a0ea076051503146c8161' for frame 'pyWorkPage' DOES NOT match record '211093964c993cedccf6be7919f14643'
2016-05-06 14:28:30,617 [read.pool t=009c3398] [ STANDARD] [ MLRCORE:01.01.01] ( mgmt.base.ThreadUITransaction) ERROR mlr.aig.net|XX.XX.XXX.XX 1059835 - ERROR: posted transaction id '9e4984f5d63a0ea076051503146c8161' for frame 'pyWorkPage' DOES NOT match record '211093964c993cedccf6be7919f14643'
2016-05-06 14:28:30,619 [read.pool t=009c62d8] [ STANDARD] [ MLRCORE:01.01.01] ( mgmt.base.ThreadUITransaction) ERROR mlr.aig.net|XX.XX.XXX.XX 1059835 - ERROR: posted transaction id '9e4984f5d63a0ea076051503146c8161' for frame 'pyWorkPage' DOES NOT match record '211093964c993cedccf6be7919f14643'
2016-05-06 14:28:30,621 [read.pool t=009c3398] [ STANDARD] [ MLRCORE:01.01.01] ( mgmt.base.ThreadUITransaction) ERROR mlr.aig.net|XX.XX.XXX.XX 1059835 - ERROR: posted transaction id '9e4984f5d63a0ea076051503146c8161' for frame 'pyWorkPage' DOES NOT match record '211093964c993cedccf6be7919f14643'
2016-05-06 14:28:30,640 [read.pool t=009c3398] [ STANDARD] [ MLRCORE:01.01.01] ( mgmt.base.ThreadUITransaction) ERROR mlr.aig.net|XX.XX.XXX.XX 1059835 - ERROR: posted transaction id '9e4984f5d63a0ea076051503146c8161' for frame 'pyWorkPage' DOES NOT match record '211093964c993cedccf6be7919f14643'
Ranjith Chinnaswamy has updated on this thread Posted transaction id DOES NOT match record? that this issue was resolved!
Here's an excerpt from Ranjith response:
"Applying hotfix and will update the result.
In our case the transaction id was generated after finished assignment and confirm harness loads, during this time the declare expression fires for properties which still post old transaction ID.
Get targets activity was called after commit."
Lochan | Online Community Moderator | Pegasystems Inc.
