IBM Filenet P8 - attached docs are empty on P8
At our client project, we use the below Perficient rulesets for IBM Filenet P8 for attachments repository.
PRFT-ECM-FileNetP8MTOM:07-10
PRFT-ECM:07-10
This integration works well for other Pega projects at this client location.
PRFT-ECM:07-10
However, when we implement in our project (CRM 7.22 on Pega 7.2), the attachment ends up in P8 with only 1KB (irrespective of the size of the original file) for .doc, .docx, .pdf files,
and with full content for .txt files.
The 1KB is for the document properties metadata required for P8 to accept.
There are no errors logged in P8 and the debugger (P8) doesn't show any alarming messages.
If anyone has similar experience, can you please share how you resolved this issue? Only .txt files attached show content on P8, not word or pdf docs.
Btw, we are not using OTB CMIS Provider 'IBM Filenet P8 [experimental]'
-Sri
