How to use a sub dataflow in dataflow
Hi, we met a issuse when using dataflow in Pega Marketing 7.21.
We used as following, more information can be reviewed in attachment file:
1) we created a dataflow X_DF in class A. It work well, and get the result expected.
2) we created a dataflow Y_DF in class B(another class), and X_DF was used as a secondary data source (not a primary source). But as a result, X_DF can not get a record this time.
Is there some problem when using like this.
In help file, it has the following description [Secondary sources are added as you start combining data. Secondary data sources can originate from a data set, data flow, or report definition.] May I use a dataflow in another class as a secondary sources?
Thank you so much for your help!
