AIG
Last activity: 29 Jun 2020 3:16 EDT
how to use react components in pega 8.3
I want to configure react js and have to develop UI using react components in pega 8.3.
I have gone through the react starter pack: https://community.pega.com/marketplace/components/react-starter-pack .
While installing i am facing Batch file not found the in the Path...I have run this command in command prompt.. Please help me to resolve this issue.
## Installation Instructions
1. Get Pega React Starter Pack zip file from Pega Exchange
2. Unzip the PegaReactStarterPack813.zip, it should create PegaReactStarterPack813 directory that contains the following sub-directories:
CableConnectApp, Documents and ReactApp
3. Using a terminal, cd into ./PegaReactStarterPack813.
4. Install Cable Connect sample application by following the instruction in ./CableConnectSampleApp.pdf
5. Make sure that your application server supports CORS.
6. Install Yarn. Installation link [here](https://yarnpkg.com/lang/en/docs/install/#mac-stable).
7. Using a terminal, cd into ./ReactApp directory and unzip PegaReact.zip.
8. Using a terminal, cd into ./pegaapp-react
9. Run the following commands:
* `yarn install`
* `yarn start`
10. This should open your browser to http://localhost:3000, which is where the application will be served.
***Edited by Moderator Kayla to update Content Type from Discussion to Question***
Check whether you have installed necessary Node and Yarn versions installed on your system and check whether you added those in the environmental variables of your system.
To verify the configuration, you can run and check the following commands in the command prompt.
If all fine, it should return the versions of the software. Then try executing "yarn install" in the appl directory.
Good Luck!
