How to use max function for more then 2 parameter in pega ?
New Stress Rate =
Max of (P1,p2,p3,p4,p5)
Param1
param2
param3
Param4
param5
New Stress Rate =
Param1
param2
param3
Param4
param5
@RaghavN2 To use the max function for more than two parameters in Pega, create a custom function that takes multiple parameters and returns the maximum value. Use this function in your Data Transform or Activity to calculate the maximum value of the parameters.
⚠ This is a GenAI-powered tool. All generated answers require validation against the provided references
Hi @RaghavN2,
You can try either of the 2 approaches mentioned below,
- You can call the function with 2 parameters recursively. Ex: max(p1, max(p2, max(p3, max(p4, p5))))
- Store all the data from the parameters into a Pagelist and utilize the OOTB max function. This will allow you to have the no. of parameters dynamic and can avoid having to make recursive calls of the same function.
