NCS
SG
Last activity: 20 Sep 2016 4:50 EDT
How to skip the link to a workobject
When using create work in a navigation rule to create a workobject, is there a way to skip the link to the workobject and directly open it? Please refer the screenshot below.
Thanks.
Yasantha Chamara.
***Updated by Moderator: Lochan. Removed user added #helpme tag. Apologies for confusion, shouldn't have been an end-user option***
FR
Did you check this option "Look for an assignment to perform after add" on the "Process" tab of your flow ?
Hi
Not sure whether I understood your query completely or not. But if the question is on how you can avoid the new harness to appear while creating the workobject then the possible solution would be to check the "Skip Create Harness" checkbox under the process tab of your flow.
NCS
SG
Hi Santanu,
"Skip Create Harness" is already ckecked.
FR
I do not have the same understanding. I think you are trying to avoid the link showing you the actual assignment of the WorkObject.
Do you know if the assignment is actually assigned to you ? If not, this is why you are getting the link.
NCS
SG
Assignment is routed to the 'current operator'
NCS
SG
Thanks for the replies.
When I create a work object pega automatically directs me to a confirm harness with the link to my work object which I need to click on to continue to my work object. I want to skip the part where I have to click the link provided and directly open the work object.
FR
NCS
SG
Hi LASSM,
No I didn't check it. Should I check it and test?
NCS
SG
This worked. Thanks a lot LASSM.
