How to Set SLA Access Group
I need to set runtime specific access group when SLA running, anyone know how to do this?
Hi @Intandhp,
Create a activity or data transform, then Add a step with the method Property-Set and then Set the property pyAccessGroup to the desired access group name and then save the activity and add it to your SLA.
Prasad.
Basically SLA works on an agent and that agent has specific access group . If you will change the Access group of that agent you can update the Access group for that SLA basically .
Hi @Intandhp,
Prasad.
