Accenture
Last activity: 23 Apr 2019 2:03 EDT
How to remove the url from Print preview
I have a print button. when i click it , it gives me a section and along with it print preview. In that print preview, i am getting the browser url. Can anyone help me in removing that url?
Can you please share your configuration. Ideally when we Print or do CTRL+P then the URL does not show up.
Please let me know in case I misunderstood anything.
Rachit
Luxoft
Hello Rachit,
We are just launching a harness on a button click. That harness has a section with fields. Is this what you are asking?
what is the kind of url you are seeing, please share,
also what is the action performe in the button for print,
I guess a simple window.print() command should help you to get the print, please check it once.
Luxoft
Hi Neha,
We are just launching a harness which has a section within it containing the list of fields to be displayed in read only mode. We have a js file in the harness which already has the window.print() command. For you to help me understand where i am going wrong, i am attaching few files: Please help!!!
1. JS file which has window.print() command
2. screenshot of the url
3. harness call on the button
I think the URL is getting printed in footer part.You can try adding CSS to remove the footer while it prints the page. Can you please check the below article.
https://www.smashingmagazine.com/2011/11/how-to-set-up-a-print-style-sheet/
Hope this helps.
Luxoft
Hello Rachit,
Tried your approach but couldn't fix the issue. I added a CSS into my harness and in that harness just gave as :
footer{
display:none;
But it is still coming up with the footer. Any further help please!!!
Accenture
Hi Laksha,
i have similar above stated requirement .can you please help me out if you know the solution.kindly do need ful.
CIBC
I am facing the same issue. Did you get solution for this issue?
Please share me if you have any solution for this.
Deeba
Accenture
Hello Deeba,
I didnt get any response neither my issue is resolved. My client accepted this as PEGA limitation and closed the issue.
